> Need Help!
post May 29, 2010 - 10:50 PM
Scosh
Joined Mar 13, '10
From New Iberia
Hey guys/girls, I have a problem. I have a 5 speed and whenever I do normal driving, the car runs excellent. But whenever I start from a stop and take the rpm over 5k and try to shift into 2nd gear it does not go into gear. Earlier today I was unable to get into 2nd, 4th, and reverse. Any advice? kindasad.gif
post May 30, 2010 - 1:48 AM
Jamchell
Joined Aug 24, '09
From San Diego, Ca
It's possible that your clutch might not be engaging all the way which will cause an issue like this. One way to test is run it in gear on a perfectly flat surface with the clutch engaged... does it want to inch slowly forward? If so, there might be air in the lines or it may need a new master or slave cylinder. The fact that reverse is tough to get into makes it somewhat likely this may be the problem.
Good luck!
post May 30, 2010 - 3:43 AM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
shifter cables
post May 31, 2010 - 9:57 AM
Scosh
Joined Mar 13, '10
From New Iberia
UPDATE
I can not get into 2nd gear when trying to turn unless I am under 20 mph. Shifts normal with regular driving, but 2nd or 4th wont catch when getting on it. kindasad.gif
post Jun 1, 2010 - 8:31 PM
Scosh
Joined Mar 13, '10
From New Iberia
Ok so now I dont have 2nd and 4th gear and sometimes reverse works. I goes into gear whenever I am parked, but if the car is moving I cannot get it into those gears. I tried letting go of the clutch slowly when I tried to shift into 2nd and it made some sort of grinding sound. Any help guys? Im off to college next weekend and I want to get my car fixed frown.gif
post Jun 1, 2010 - 8:37 PM
D-Man
Joined Jan 18, '08
From Houston
Check shifter cables first. Make sure the pin is on right and everything. Not pinched.
Stop hard-dogging it all around town.
Then if either of those dont work, then you may have messed part of your shifter assy within the transmission. It's possible that you've ground the gears a bit doing that; and that ground bit is clogging up your movement. If that's the case you'll need a new one. Hope thats not it.
Damn D-Man - most impressive.
post Jun 1, 2010 - 8:40 PM
Scosh
Joined Mar 13, '10
From New Iberia
Ok thank you, Ill check first thing tomorrow. And it started doing that when I was just cruising around my neighborhood pressing the gas lightly.
post Jun 1, 2010 - 8:50 PM
D-Man
Joined Jan 18, '08
From Houston
funny isn't it? I find that most fuel pumps go out when the car isn't running as well. Dosen't make sense, but it happends.
You do know where and witch shifter cable you're looking for;' correct?
post Jun 1, 2010 - 8:52 PM
Scosh
Joined Mar 13, '10
From New Iberia
I actually do not. Do you mind telling or showing me what look at?
post Jun 1, 2010 - 9:12 PM
D-Man
Joined Jan 18, '08
From Houston
If you pop your hood. and you stand facing your winshield. Your engine is to the left and the tranny is to the right.
On the right (driver side) frame rail, locate your fuel filter.
EDIT: Driverside if it's USDM
Now the shifter cables are cables with round "washer" shaped objects on the end. (just really fat washers) they also have PINS to hold the tie bars within the cables hooks.
Now if that's all good then follow the cables from the tranny there, back twards the firewall. You'll find the mounts about 6-8 inches away. MAKE SURE THE CABLES SIT IN THE MOUNTS! and Make sure the Mount-Clips are in place~ Tightly!! This will fcuk up your shifting.
IIRC: I believe your Problem will be here, on the top cable. ( it determines (iirc) up and down, the bottom determines left and right @ shifter) yes you can move these and move your shifter into gear so DO NOT do this with the car running!!!!!!!!!!!!!
cool?
This post has been edited by D-Man: Jun 1, 2010 - 9:12 PM
post Jun 1, 2010 - 9:17 PM
Scosh
Joined Mar 13, '10
From New Iberia
Ok, thank you very much. Ill try this tomorrow and tell you how it goes.
post Jun 2, 2010 - 7:39 AM
Scosh
Joined Mar 13, '10
From New Iberia
The shifter cables are fine and in the mounts. I guess she is staying home while Im in college, I dont have the time or money to fix it atm. frown.gif
post Jun 2, 2010 - 7:47 PM
D-Man
Joined Jan 18, '08
From Houston
QUOTE (Scosh @ Jun 2, 2010 - 7:39 AM) *
Pop out your center console. Check the cables on your shifter.
EDIT, check your shifter all together.
This post has been edited by D-Man: Jun 2, 2010 - 7:48 PM
post Jun 2, 2010 - 8:27 PM
Scosh
Joined Mar 13, '10
From New Iberia
What am I supposed to look for in my shifter? My cables are good.
post Jun 3, 2010 - 4:27 PM
GriffGirl
Joined Feb 7, '07
From Portland, Oregon
It sounds to me like your clutch is going out. Maybe you burnt it out shifting into 2nd at 5K RPMS. WHY are you shifting at 5K RPMS!?
post Jun 3, 2010 - 4:41 PM
samir0189
Joined Mar 8, '08
From Orlando, Florida
QUOTE (GriffGirl @ Jun 3, 2010 - 5:27 PM) *
My F/S Thread!
Ferdi says (11:29)
post Jun 3, 2010 - 10:34 PM
Scosh
Joined Mar 13, '10
From New Iberia
I got a new clutch installed 6** miles ago. And 5k was a round off, its was like around 4.5 or so and it was just one of those times when you want to just get on it.
post Jun 3, 2010 - 11:26 PM
Jamchell
Joined Aug 24, '09
From San Diego, Ca
Have you checked to see if your clutch is engaging all the way yet? The fact that your clutch was just worked on 6xx miles ago makes it even more likely. I'd take it back to the shop if it was that recently done.
post Jun 4, 2010 - 3:34 AM
Raves44
Joined Mar 26, '09
From Colorado Springs
hey i had this exact problem with my celi. one thing you can do to see if it could be the cables is have someone move the shifter in the car while you look at where the cables hit the transmission. figure out what gears go where and have them push in the clutch and shift it with your hands. if it will go into gear like this is mostliikely your cables. i did this from driving like a jerk trying to throw it into gear and it actually snapped some of the cable. i mean not even all of the cable and it throws the whole thing off. the thing was i didnt even see where the break in the cable was untill i pulled the cables off of my car. and the good part is if it is the cables that is a relatively cheap part and its easy to install. hopefully this helps. if you need anything else you can just pm me.
Raves
post Jun 4, 2010 - 1:06 PM
GriffGirl
Joined Feb 7, '07
QUOTE (Scosh @ Jun 3, 2010 - 8:34 PM) *
Still, you're shifting at too high RPMs and you're just burning up your clutch. So it's entirely possible that your clutch is going out. When you got it replaced (how many miles ago? 600x?) did you have the flywheel turned? Replace the throwout bearing? What kind of clutch (brand, type) did you install? And who did the work?
Lo-Fi Version Time is now: December 2nd, 2024 - 3:43 AM
