> strut bar
post May 31, 2010 - 9:31 PM
stwin2
Joined Apr 9, '10
From raleigh n.c.
i was told that a dodge neon strut bar would work on a celica. is this true and would it clear a 5s.
post Jun 1, 2010 - 12:59 AM
zonz540
Joined Jul 3, '09
From UT
It works, but you have to drill your own holes. Get the one with a full circle around the strut brace, the crescent shaped ones only bolt up to one stud because of where the Dodge studs are placed.
post Jun 1, 2010 - 2:47 AM
cheela
Joined Feb 2, '07
From Berlin, WI
if you don't wanna drill into anything you could just get this one.
http://cgi.ebay.com/ebaymotors/Toyota-Celi...s#ht_2109wt_618
it'll fit perfectly and it clears the STs. I'm sure the GTs won't be that much difference either.
post Jun 1, 2010 - 10:56 PM
VieT9sD
Joined Apr 7, '09
From NorCal
QUOTE (cheela @ Jun 1, 2010 - 3:47 AM) *
does the ebay strut bar make a difference in terms of handling? i want to get one too but im a little skeptical of them.
post Jun 1, 2010 - 11:02 PM
cheela
Joined Feb 2, '07
From Berlin, WI
well i think that it does. I haven't tried cornering super hard with it on but i have felt a difference from before. I think it performs a little better than the stock GT strut bar that connects to the firewall.
post Jun 2, 2010 - 1:38 PM
sunwukongg
Joined Mar 10, '08
From Socal, OC
QUOTE (cheela @ Jun 2, 2010 - 12:02 AM) *
has anyone tried this on the GT?
post Jun 2, 2010 - 5:44 PM
mariosdarkworld
Joined Aug 13, '07
From Arizona
I was thinking about making a custom made one but idk I'd have to talk to my cousin he's a 15 yr exp welder Im pretty sure it would be cheaper. Didn't sum1 here make sum custom ones?
post Jun 2, 2010 - 11:13 PM
zonz540
Joined Jul 3, '09
From UT
It makes a difference. It stiffens the front quite a bit if you get a decent one and add suspension.
Lo-Fi Version Time is now: April 21st, 2025 - 7:04 PM
