> Squeeling sound under the hood
post Jun 2, 2010 - 10:41 AM
H1gherReflex
Joined Feb 21, '10
From Elizabethtown, KY
This has been happening for awhile now. Initially I had a bad serpentine belt and replaced it. The sound stopped for awhile but eventually came back. Now I have no idea what is causing the sound. I added power steering fluid and that worked to a degree but now that doesn't have any affect at all. The sound seems to stop once I either hit a certain amount of RPM's or once the car has been in motion for awhile. I was wondering if anyone could give me some answers. Here is a vid for further examination.
http://www.youtube.com/watch?v=ZH2lpxHPv48
HONDA
Hold On Not Done Accelerating
post Jun 2, 2010 - 10:59 AM
rave2n
Joined May 29, '09
From Gainesville, FL
Make sure that belt you just replaced is not to tight, or to lose. Also confirm other things that are on that belt are functioning correctly.
post Jun 2, 2010 - 11:02 AM
samir0189
Joined Mar 8, '08
From Orlando, Florida
wow. looks like you have a 5th gen steering wheel.
Anyway, it could be any of the pulleys maybe making noise, also does the ST have a separate power steering belt? could be that belt making noise if so.
My F/S Thread!
Ferdi says (11:29)
post Jun 2, 2010 - 11:09 AM
rave2n
Joined May 29, '09
Yea the power steering is a seperate belt.
post Jun 2, 2010 - 11:53 AM
H1gherReflex
Joined Feb 21, '10
I'll check all that out. How tight should the belt be on?
HONDA
post Jun 2, 2010 - 12:44 PM
GriffGirl
Joined Feb 7, '07
From Portland, Oregon
Try getting some belt dressing (it comes in a spray can, you can buy it at any parts store) and spray the inside of your belts with it, and see if the squealing stops. If your belts are on properly, and they're in good shape, you could just need to apply that belt dressing which will stop the squealing noise.
post Jun 2, 2010 - 1:48 PM
HectortheRican
Joined Dec 26, '09
From Albuquerque, NM
The same thing happened to me, I replaced all my belts and it still did it, but once the weather started warming up it doesn't happen anymore. So I guess the motor just need to warm up.
June '12 COTM
'95 AT200
post Jun 2, 2010 - 7:10 PM
GriffGirl
Joined Feb 7, '07
It's not the motor, it's the belts that are warming up, and the belt dressing will eliminate the issue if that's all it is
post Jun 3, 2010 - 4:48 PM
k-weaver
Joined Jun 5, '07
From Santa Maria
QUOTE (GriffGirl @ Jun 2, 2010 - 6:44 PM) *
X2 on this
HOWEVER,
I had a smilar problem and used belt dressing. When I had applied it the noise got worse (much louder). Turned out it was my alternator pully.
post Jun 3, 2010 - 7:50 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
RUNN!!!!! ITS GONNA BLOW! I HAD A 7AFE DO THAT!!!!!!!!!!
post Jun 4, 2010 - 2:57 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
jk btw.
the ST has 3 belts under the hood. one for A/C, one that goes to the crank-alternator-water pump, and one thats water pump-power steering pump
post Jun 4, 2010 - 3:36 PM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
Take all of the belts off.
**** Photobucket
post Jun 10, 2010 - 4:36 PM
Kharma
Joined May 20, '10
From DFW
I have that same exact noise, but happens only when i start the ac.... frown.gif not good for me.
post Jun 10, 2010 - 6:24 PM
95CelicaST
Joined Feb 5, '05
Replace your a/c belt. 20 minutes tops.
**** Photobucket
post Jun 11, 2010 - 10:46 AM
Kharma
Joined May 20, '10
From DFW
when i freely turn my ac it still makes that squeel.. i think it is a bad bearing
post Jun 11, 2010 - 3:21 PM
GriffGirl
Joined Feb 7, '07
QUOTE (Kharma @ Jun 11, 2010 - 8:46 AM) *
That's the pulley, not a bearing, that's making that noise.
post Jun 11, 2010 - 4:33 PM
Kharma
Joined May 20, '10
From DFW
So how would i be able to get rid of that noise then?
By the way thanks for the help
post Jun 14, 2010 - 12:07 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
buy & replace the "a/c magnetic clutch"
Lo-Fi Version Time is now: November 23rd, 2024 - 4:20 AM
