> Cruise control and airbag fuses, where are they?
post Jun 2, 2010 - 7:19 PM
GriffGirl
Joined Feb 7, '07
From Portland, Oregon
Still can't get my cruise to work properly since swapping in the 7th gen steering wheel, and I'm fairly certain I wired it in correctly, so I want to check and see if maybe I just blew the fuse the first time I wired it in incorrectly.
Airbag light is still on too, I'm thinking I toasted the sensor when I wired it in incorrectly the first time (prior to getting the adapter), not sure.
And where's the airbag fuse so I can make that little red man in my dash stop mocking me? laugh.gif
post Jun 2, 2010 - 7:47 PM
richee3
Joined Jun 29, '08
From Denver
Did you look under the hood for the cruise control fuse? I'm fairly certain it's in that box. I could be mistaken though.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Jun 2, 2010 - 7:54 PM
disconnect the ecu for a while to clear the airbag light.
post Jun 2, 2010 - 8:47 PM
Johnnyny
Joined Apr 28, '09
From York pa
QUOTE (njccmd2002 @ Jun 2, 2010 - 8:54 PM) *
doesnt work i tried
post Jun 3, 2010 - 5:46 AM
it worked for me. hmmm maybe need to unplug the battery, that resets the airbag module.
post Jun 3, 2010 - 1:30 PM
GriffGirl
Joined Feb 7, '07
I know how to reset the airbag module, you bridge TC and AB and ground them alternately, etc. But it didn't work. So now I just want that little man to stop mocking me.
Anyway so yeah, I looked under the hood for the cruise fuse (hey, that rhymed laugh.gif ) but didn't find it, maybe i just missed it
post Jun 3, 2010 - 4:16 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
ill fix the airbag when you get here, as for the cruise, did you use the stock control? im using the stock controller in the 7th gen wheel
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Jun 3, 2010 - 4:26 PM
GriffGirl
Joined Feb 7, '07
QUOTE (Smaay @ Jun 3, 2010 - 2:16 PM) *
No, I'm set on using the 7th gen stalk. I still have my 6th gen one though, but it's one of those OCD detail things, ya know? I just need to check the fuse at least before I delve further into it.
Lo-Fi Version Time is now: December 2nd, 2024 - 3:00 AM
