jordisonjr's photography/progress thread, Projectors and Fog lights installed. |
Jun 19, 2011 - 5:14 PM |
Enthusiast Joined Jan 20, '09 From Winnipeg Currently Offline Reputation: 5 (100%) |
Quick update.
Thanks to Batmans advice, I was able to remove the control arm from the passenger side, and got one of the bushings out. Now I just gotta torch what's left of the bushings, and then wait for the new bushings to arrive. And figure out how to save my endlink on the driver side. -------------------- -Protection mode, For when your amp tries to blow its load. 1995 Toyota Celica GTS - Daily Driver 1999 Chevy Cavalier - Winter Beater 1994 Honda Civic CX Hatchback - Dead My Celica! |
Jun 19, 2011 - 6:45 PM |
good job man.
Jun 21, 2011 - 1:53 PM |
Woooo!!
While I went to get a torch to remove the remainder of the bushings from the passenger side control arm, somehow my dad got the driver side endlink without cutting it. So last night I finished everything I could do; I removed the driver side control arm, and forced the bushings out using a drill, hammer, and a propane torch. Just have to wait for the bushings to get here and then I can finish the job off. I just wish Canada Post wasn't on strike right now.. Does anyone know if the control arms will be just as difficult to get back into the car as they were to remove? -------------------- -Protection mode, For when your amp tries to blow its load. 1995 Toyota Celica GTS - Daily Driver 1999 Chevy Cavalier - Winter Beater 1994 Honda Civic CX Hatchback - Dead My Celica! |
Jun 21, 2011 - 3:11 PM |
Enthusiast Joined May 31, '11 From Rochester, NY Currently Offline Reputation: 5 (100%) |
They will be harder. Your best bet is to bring it to a shop with a press and have them press them in. If you have a shop like Advance Auto Parts, we have a loaner tool program and you can try using the rental press... but idk if it'll work.
-------------------- 1994 Toyota Celica GT-S 5S-FE 190k Miles. Project car 1992 Toyota Celica GT 5S-FE 170k Miles. Daily driver/beater 1999 Toyota Camry LE 5S-FE 216K Miles. RIP You will be missed. *ASE Certified General Manager |
Jun 21, 2011 - 3:23 PM |
Im talking about gettin the control arms mounted into the car, not the bushings into the control arm.
I'm already expecting to have some problems getting the bushings into the arms, but Ill give it a shot myself. -------------------- -Protection mode, For when your amp tries to blow its load. 1995 Toyota Celica GTS - Daily Driver 1999 Chevy Cavalier - Winter Beater 1994 Honda Civic CX Hatchback - Dead My Celica! |
Jun 21, 2011 - 6:51 PM |
make sure you get the metal ring out of the arm bushing holes. Use a dremal or something to cut just the ring, then use a chisel and hammer to pop it out. Getting the bushings in is easy, use a vise and don't be shy on the lube.
Getting the arm back in is 100% easier then taking it out. -------------------- |
Jun 21, 2011 - 7:37 PM |
Do you mean a metal ring that would sit on the outside of the bushings, but the inside of the control arm(hole for the bushings)?
Me and my dad were looking at it, and I couldn't figure out if there was a ring in there that had to be removed or not. EDIT Just took a look at it and I do have to remove that ring. Is a dremel strong enough? or could I use something like a wire wheel on a drill? Do I have to worry about the inside of the control arm getting scratched/marked up from removing that ring? And is this ring only on the larger diameter bushing that mounts to the chasis? The smaller diameter one did not require a torch, i was able to just pound that one out with a hammer This post has been edited by jordisonjr: Jun 21, 2011 - 7:46 PM -------------------- -Protection mode, For when your amp tries to blow its load. 1995 Toyota Celica GTS - Daily Driver 1999 Chevy Cavalier - Winter Beater 1994 Honda Civic CX Hatchback - Dead My Celica! |
Jun 21, 2011 - 8:04 PM |
both rings should came out (the small with the bushing as you know), just take the ring out of the big hole, don't worry.
I used a sawz-all but I was careful, I wouldn't reccomend using one because you can damage the bushing hole. Just get the ring out, the bushing fits better without. -------------------- |
Jun 21, 2011 - 8:08 PM |
Do you think a hammer and large flat head screw driver would get it out?
Without causing damage to the big hole -------------------- -Protection mode, For when your amp tries to blow its load. 1995 Toyota Celica GTS - Daily Driver 1999 Chevy Cavalier - Winter Beater 1994 Honda Civic CX Hatchback - Dead My Celica! |
Jun 28, 2011 - 3:26 PM |
Enthusiast Joined Sep 18, '04 From Manitoba, Canada Currently Offline Reputation: 1 (100%) |
so have you fixed it up yet? hopefully you'll be able to drive it soon!!
Jun 28, 2011 - 4:07 PM |
Not yet, because Canada post just felt they had to go on strike as my parts were in the mail.
My car is sitting on jack stands with a missing strut and no control arms. Hopefully they will be here soon. Then I can get them on, and allignment done and FINALLY get it going again. Can't believe I ahve only driven it once in the past 6 months, -------------------- -Protection mode, For when your amp tries to blow its load. 1995 Toyota Celica GTS - Daily Driver 1999 Chevy Cavalier - Winter Beater 1994 Honda Civic CX Hatchback - Dead My Celica! |
Jun 28, 2011 - 4:24 PM |
they're back to work today!!! hopefully you get your parts soon.
Jun 28, 2011 - 6:36 PM |
haha yea I've been watching it like a hawk lately, but apparently it may take up to a week to clear the back log, but I'll keep my fingers crossed
Jun 28, 2011 - 7:33 PM |
It's going to be like christmas when it comes! Good luck!
Jun 28, 2011 - 8:10 PM |
You sure got that right!
And thanks This post has been edited by jordisonjr: Jun 28, 2011 - 8:10 PM -------------------- -Protection mode, For when your amp tries to blow its load. 1995 Toyota Celica GTS - Daily Driver 1999 Chevy Cavalier - Winter Beater 1994 Honda Civic CX Hatchback - Dead My Celica! |
Jul 22, 2011 - 10:25 AM |
update ?
Jul 22, 2011 - 12:41 PM |
Haha, just a little ahead of me.
Well after a **** load of frustration and waiting, its FINALLY driveable. The lowere control arm bolts were stripped so I just order some new botls from toyota and they worked fine. So I got it all together last night and it rode good. However i am still getting a clunk sound similar to blown struts coming from the rear, even though I changed the mounts. This is what I replaced: http://cgi.ebay.ca/KYB-Rear-Strut-Mount-/3...=item5ae1a288e2 in the front and the rear, along with all 4 struts. I'm thinking maybe there are some other componants of the mount that should have been replaced as well? Either than that the car runs pretty good, and i'm pretty satisfied I finally ahve it done, I thought this time was never going to come haha. -------------------- -Protection mode, For when your amp tries to blow its load. 1995 Toyota Celica GTS - Daily Driver 1999 Chevy Cavalier - Winter Beater 1994 Honda Civic CX Hatchback - Dead My Celica! |
Jul 23, 2011 - 7:36 PM |
Are the KYB's cartridge type? Did you get struts or the shock insert? If it's the insert, make sure the holding device is tightly secured. Sometimes the nut on top (or bottom like in my Koni case) is coming lose and makes a horrible sound.
Jul 24, 2011 - 2:16 AM |
Are the KYB's cartridge type? Did you get struts or the shock insert? If it's the insert, make sure the holding device is tightly secured. Sometimes the nut on top (or bottom like in my Koni case) is coming lose and makes a horrible sound. I got the full struts. So All I had to do is take my old ones out and put the new ones in, not just cartriges. -------------------- -Protection mode, For when your amp tries to blow its load. 1995 Toyota Celica GTS - Daily Driver 1999 Chevy Cavalier - Winter Beater 1994 Honda Civic CX Hatchback - Dead My Celica! |
Aug 4, 2011 - 11:19 AM |
Washed the car up quick today, and snapped a couple pics with my sisters crappy point and shoot.
Didn't really know what I was doing so I just threw it on auto haha. Some are pretty dark, put osme turned out pretty good IMO. Car is in need of a good wash/clay bar/wax, which I might get around to this weekend depending on the weather. Any tips/opinions welcome. -------------------- -Protection mode, For when your amp tries to blow its load. 1995 Toyota Celica GTS - Daily Driver 1999 Chevy Cavalier - Winter Beater 1994 Honda Civic CX Hatchback - Dead My Celica! |
Lo-Fi Version | Time is now: November 23rd, 2024 - 3:28 PM |
