4 Pages V  < 1 2 3 4 >
> need help....rebuilding a 5sfe, new problem, wont start nor crank !!
post Aug 17, 2010 - 8:25 PM
D-Man
Joined Jan 18, '08
From Houston
Okay yeah, E-Bay kit is failboat city. Hah.
Also, Steven is a mad geinus, Heed his words.
Finaly, Do not Never, Ever doubt the ability for things to fail on you when you haven't even touched them.
You're only getting a clicking sound? No "reh-Heh" noise at all? Could be starter. Is everything grounded well? And you replaced the large gauged positive starter terminal cable on it TIGHTLY? That can lead to a burt out starter too.
What was the result of the test anyway?
Damn D-Man - most impressive.
post Aug 18, 2010 - 12:35 AM
Malhar95
Joined Jul 5, '09
From Katy/houston
starter is fine, changed the plug but same symptoms...
and if the kit was bad, then should i be getting the "reh-heh" sound or something?
post Aug 18, 2010 - 2:36 AM
Malhar95
Joined Jul 5, '09
From Katy/houston
oh and i do smell a little gas(petrol)...not much but just a little!
post Aug 18, 2010 - 3:15 PM
rave2n
Joined May 29, '09
From Gainesville, FL
Air, Fuel, and Spark? Got'em, find what your missing, start from there.
post Aug 18, 2010 - 3:18 PM
JuMPiiN
Joined Nov 10, '09
From Louisiana
Grounds.....
post Aug 18, 2010 - 4:23 PM
Malhar95
Joined Jul 5, '09
From Katy/houston
rave2n Posted Today, 04:15 PM
how do i check
Grounds.....
if it was a grounding error...should i not be able to listen to the stereo or anything?
post Aug 18, 2010 - 9:33 PM
pipes
Joined Apr 23, '08
From boston MA
QUOTE (Malhar95 @ Aug 18, 2010 - 5:23 PM) *
how do i check
Grounds.....
check your fuse box and make sure you clipped it in properly because you prolly have it loose
post Aug 18, 2010 - 11:22 PM
RavenAegis45
Joined Jun 25, '08
From CA
QUOTE (JuMPiiN @ Aug 18, 2010 - 4:18 PM) *
Grounds.....
I was thinking the same thing, I helped with an Engine swap in my friends Civic, we did everything right hooked up everything the way it was suppose to be hooked up and it wouldn't start, we started looking around and my friend bumped a wire against the frame and a huge spark scarred the crap outta us and I asked if he connected the grounds, funny thing it was all it needed lol
post Aug 19, 2010 - 12:23 AM
chinamandrift
Joined Apr 7, '09
From cali
use a volt meter dc volt setting
pos lead to starter casing
ned lead to neg post on the battery
have a friend turn the key trying to crank
while trying to crank you should have less then .2v or 200mv
if you have any more then that you have a bad ground connection or ground wire
post Aug 19, 2010 - 2:06 PM
Malhar95
Joined Jul 5, '09
From Katy/houston
okay i was looking through all the wires, and then WOW....i forgot to ground the starter!!!
i felt so dumb!!!
but another problem cam up, now gas is leaking from the injector place...
which brings up another question..
are there any kind of rings which to in the injectors or rail or head cuz i had A LOT of them left after the rebuild...
i picture would really be nice, like of what goes b/w the injectors...
post Aug 19, 2010 - 4:02 PM
RavenAegis45
Joined Jun 25, '08
From CA
QUOTE (Malhar95 @ Aug 19, 2010 - 2:06 PM) *
i felt so dumb!!!
Wow you had spare parts left over? thats always a bad thing if you know you didn't buy them as extra's. well the fuel injectors have a grommet and O-Ring but i'm not an expert on this
post Aug 19, 2010 - 10:58 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
yeah they have o-rings. both on the fuel rail (top of injectors) and bottom (manifold side)
post Aug 20, 2010 - 3:26 AM
Malhar95
Joined Jul 5, '09
From Katy/houston
yup it was the "O-ring problem" and thats solved....
but now my engine oil i believe is leaking...my mechanic i gone and will be back in about a week...any suggestions what it could be?
its leaking from behind the timing belt place...
what i think is that its rubber thing which is on the head...it looks like a filler to keep the oil in....i think its suppose to be metal and not rubber b/c my old head has steel..but my mechanic thinks im wrong and it might be the oil pump...
ill get some pics soon...
PS: if somebody is in the houston area, can u please please come over and take a look...maybe its something stupid..i would really appreciate it....i live on the westgreen and fry rd intersection somewhat near i-10 and mason..(next to the fire station)
thank you
post Aug 21, 2010 - 9:29 PM
D-Man
Joined Jan 18, '08
From Houston
Tranny didn't have a fluid pan, Throttle cables ripped up, Peices missing, Hoses split, EGR incomplete, PS fluid everywhere, Bad Oil smell, Random things grinded/cut off, CV axle boots not secured, Random peices of steel welded between something and nothing, Gaskets leaking, 2 jackoff mechanics involved, a driveway full of standing fluids, wrong fluids in the wrong places, disconected yet standing mechanical and electrical systems, A slew of plugs not pluged into their devices, cut wires, striped wires, Burnt wires, cut and improperly reconnected wires (that were connected to wrong wires) Missing componets, poorly placed aftermarket componets, sensors unlocated (and freehanging) signs of corrosion, Mechanical lines running in the wrong directions, and a partriach in a pair tree...
Oh and that was just the first 60 seconds of our meet n greet. There is indeed moar to this story. I just looked at the surface.
We've alot of work ahead of us bro, But we'll get her up to par.
I'll call ya tommorow, And we'll get that tranny pan as promised. Remind me to compile a list of sh!t you're gunna be needing, and get ready to make a few deals with Alex and Steven, and Anyone else who may have what you need. Otherwise, I'll let you get in on some of my junkyard/"seedy parts shop" hookups.You remember what i told you about those places wink.gif lol!
Sry 6g, This will not be a small project.
Malhar, i think you need to start a project thread. List every detail as you do it, so we have refference. Pictures are golden. this will help us in the future, as we'll have a history book to refer too. Plus give other members a place to help find your error, Opposed to individual issue thread hoping, and 40 PM explinations stating the same thing over and over.
This post has been edited by D-Man: Aug 21, 2010 - 9:32 PM
post Aug 21, 2010 - 10:04 PM
JuMPiiN
Joined Nov 10, '09
From Louisiana
Whew... sounds like my 6th gen when i picked it up the first time. His sounds a bit worse. Hope you have alot of time on your hands the next few weeks.
post Aug 22, 2010 - 12:36 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
FYL dude.
ive got a garage full of 2 dead celicas parts.. i may have some stuff for you
post Aug 22, 2010 - 1:13 PM
JuMPiiN
Joined Nov 10, '09
From Louisiana
maybe i should take a drive over there and bring some cash. lmfao
post Aug 22, 2010 - 3:13 PM
SleekCelica
Joined Mar 28, '10
From Columbia, South Carolina
Either grounds, or your battery connections/battery itself.
1994 Celica GT, coupe, 5 speed.
Front strut brace, cherrybomb glasspack, intake.
post Aug 23, 2010 - 11:45 PM
RavenAegis45
Joined Jun 25, '08
From CA
QUOTE (D-Man @ Aug 21, 2010 - 10:29 PM) *
Haha wow that sucks but I like how you soften the blow by saying something good he has, well best of luck on the restoration, from the sound of things your gonna need it but be glad you have people to support you like D-Man
post Aug 24, 2010 - 12:49 AM
Malhar95
Joined Jul 5, '09
From Katy/houston
haha yea im pretty much screwed, but i am glad that dman came and took a look at the car...i was gonna buy some useless things to fix it my self but then he came and saved the day biggrin.gif
Lo-Fi Version Time is now: February 21st, 2025 - 4:31 PM
