![]() Enthusiast ![]() Joined Oct 24, '09 From New Zealand Currently Offline Reputation: 0 (0%) ![]() |
currently I got front calipers what else do i need to get just spacer and rotor??can anyone giv me a list, thanks.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 17, '06 From New Jersey Currently Offline Reputation: 105 (100%) ![]() |
is it a ST202 with superstrut suspension ?
Enthusiast ![]() ![]() ![]() Joined Feb 2, '06 Currently Offline Reputation: 3 (100%) ![]() |
search for st205 brakes.
then look for a username Lubu or any other thread should suffice. |
Enthusiast Joined Oct 13, '10 From Trinidad Currently Offline Reputation: 0 (0%) ![]() |
Hi guys, Newbie here. I have an st205 and want to change from super strut to strut suspension. I can get the st202 complete front suspension, but i want to use the st205 big brakes on it. is there anyone that did the conversion? Is it difficult or involves machine shop work?
Thanks |
you need
Cadillac catera 2002 front disc with 5 x 100 bolt pattern custom drilled 3 mm spacer 9/16 fine thread tap 9/16 fine thread bolts ( 4 ) 1/4 inch nuts ( optional ) 9/16 drill bit ST205 brake lines ST205 calipers ( may or may not need modification, read at the end ) use the thread tap the put threads on the knuckle where the caliper will be bolted on to ![]() ![]() use the drill bit to make the holes on the caliper wide enough so the new bolts can go through them if using the nuts, get them welded on the outer side of the knuckle ( if doing this, no need to make threads on the knuckle ) at this point you can start putting things together install the 3 mm spacers before the disc, that way the disc is pushed out a little, if this spacer is not used the disc will come in contact with the ball joint. ![]() slide the disc in place ( 15mm wheel spacer pictured needed because my wheels didn't clear the caliper, you may or may not need one depending on your wheels ) ![]() bolt the caliper down ![]() ![]() bleed the system, and mount wheels enjoy ! PS the caliper may need to have some material grinded off from the contact side of its bracket, I have found that there are minor differences on knuckles from different years, on my 1995 knuckle I needed to grind away ~ 2 mm of material, recently I switched to a 98 knuckle and I needed to add a 1/4 inch washer to make the caliper be centered with the disc again, it bogged me for days so I took everything apart and in fact the knuckles have different thickness at the contact area. This post has been edited by Culpable04: Oct 13, 2010 - 10:43 PM -------------------- ![]() |
Enthusiast Joined Sep 30, '10 From Bklyn Currently Offline Reputation: 0 (0%) ![]() |
I have a 95 GT what will I need to do to get them on and workin perfect I mean is there any difference since I have a GT model info plz thanks
-------------------- (Oo__oO) 1995 Celica GT 2.2L. 5sfe coupe She stock for now
no difference, ST or GT, uses same parts and same procedure
Lo-Fi Version | Time is now: February 20th, 2025 - 4:00 PM |
