GT-4 fog lights, Bulb size |
Jun 7, 2010 - 10:39 PM |
Enthusiast Joined Jul 28, '09 From Christchurch, New Zealand Currently Offline Reputation: 1 (100%) |
One of my fog lights has blown and was jst wondering bulb size also is there a ay to get it out ithout removing the plastic underneath?
Jun 8, 2010 - 12:33 AM |
Enthusiast Joined Jun 29, '03 From 캘리포니아 Currently Offline Reputation: 23 (100%) |
The fog lights use an H3 bulb. Is there a reason you do not want to remove the plastic underneath? It's only a few bolts to move it out of the way, and it would seem like the easiest solution. You could try to fit your hands through the grill and work from there, but you would not be able to see what you are doing.
Jun 8, 2010 - 10:15 AM |
Pop off the plastic fog light surround then you can remove the lamp for easy access.
Jun 8, 2010 - 10:42 AM |
Enthusiast Joined Apr 20, '09 Currently Offline Reputation: 4 (100%) |
The fog lights use an H3 bulb. Is there a reason you do not want to remove the plastic underneath? It's only a few bolts to move it out of the way, and it would seem like the easiest solution. You could try to fit your hands through the grill and work from there, but you would not be able to see what you are doing. Only reason I could think of is that all of the bolts are rusted. I know on my old Celica all of the bolts that held on the plastic were rusted shut, and PB Blaster did nothing. They either came out with way too much force, the heads snapped off, or the plastic broke. -------------------- ~Moving on to a 2002 Corolla S~ R.I.P Tom Celica - 1994-2010 |
Jun 13, 2010 - 4:58 AM |
yea cus its been raining solidly for the past 2 weeks and dont want to get wet crawling under my car lol dont kow if the bolts are rusted or not will give popping the plastic off a go though
Lo-Fi Version | Time is now: January 10th, 2025 - 3:35 AM |
