> Toyota Security, Does my car have it?
post Jun 8, 2010 - 4:26 PM
Driver
Joined Apr 3, '10
I've been curious since I bought my car... Is this the RS3000 VIP system? My car never came with a key fob, only the original key and valet key. If I bought a fob off eBay or something, would it work? I found a thing on how to program it. My car is a 1997 GT.
post Jun 8, 2010 - 4:54 PM
JuMPiiN
Joined Nov 10, '09
From Louisiana
My car had that I ripped it out. But I did get a auto lock key and such with my keys. You can go to Toyota and order one for cheap.
post Jun 8, 2010 - 5:18 PM
richee3
Joined Jun 29, '08
From Denver
Yes, you should be able to buy a new key fob and reprogram it. As long as it's the right key fob.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Jun 8, 2010 - 5:25 PM
Keiri
Joined Mar 6, '04
From Charlotte, NC
That's what my RS3000 equipped '99 has. To double-check/verify check under the seat for a black or gray box with a single wire cluster running into it that's held in place on one side with a zip-tie. That, if there is one in your car, is the control/programming box for the system and you'll need the fob, a paper clip, and about 5 minutes to program it.
The fob you need can be purchased from eBay for between $25 and 50 dollars. You want the oval shaped fob (gray or black - I have one of each and both work) with two buttons and information on the back as such:
FCC ID: BAB237131-022
CANADA 2024101526
MADE IN JAPAN
Just search for "Toyota fob BAB237131-022" and you should find exactly what you need.
Has no more Celicas
post Jun 8, 2010 - 6:52 PM
Driver
Joined Apr 3, '10
post Jun 8, 2010 - 7:09 PM
Keiri
Joined Mar 6, '04
From Charlotte, NC
Has no more Celicas
Lo-Fi Version Time is now: November 29th, 2024 - 7:25 PM
