Idle Problem. |
Idle Problem. |
Jun 12, 2010 - 2:06 AM |
Enthusiast Joined Jun 17, '08 From Mexico Currently Offline Reputation: 0 (0%) |
I have a celica 95 GT and the problem is that the engine's idle speed is 1,100 RPM and I can't adjusted to 750 RPM, I try to rotate the distributor, what else can I do?
Jun 12, 2010 - 9:18 AM |
Enthusiast Joined Dec 26, '09 From Albuquerque, NM Currently Offline Reputation: 19 (100%) |
Get a manual for our car. The kind you can buy at Pep Boys. Because it have one and it talks about a screw close to the throttle body that you can turn to adjust the idle speed to your preference. I'm not at home, otherwise I'd post what it says. Plus there's diagrams
June '12 COTM '95 AT200 |
Jun 15, 2010 - 1:46 AM |
The distributor adjusts timing, not idle speed. Don't mess with the timing unless you know what you're doing.
Lo-Fi Version | Time is now: November 25th, 2024 - 9:45 PM |
