Enthusiast ![]() ![]() Joined Jul 23, '08 From Hawaii Currently Offline Reputation: 6 (100%) ![]() |
just as the title, due to the top mount inter-cooler setup on the 3sgte, is the GT4 style hood required for optimal performance?
![]() Enthusiast ![]() ![]() ![]() Joined Jan 10, '09 From Burtonsville, Maryland Currently Offline Reputation: 1 (100%) ![]() |
just as the title, due to the top mount inter-cooler setup on the 3sgte, is the GT4 style hood required for optimal performance? yes, if you go with a TMIC. The GT4 hood is functional for TMIC. -------------------- THIS IS WHERE WE HOLD THEM!
Still trying to find the cure for ST205 asthma.. 6gc.net's outlaw vigilante because im a LEADER not a follower. ![]() |
just as the title, due to the top mount inter-cooler setup on the 3sgte, is the GT4 style hood required for optimal performance? yes, if you go with a TMIC. The GT4 hood is functional for TMIC. No, its not. The hood has nothing to do with the intercooler, and is not needed for a 3sgte swap. The only benefit to the hood is over all better engine bay cooling, and it makes for a nicer looking car. -------------------- 15PSI - 30MPG - Megasquirt Tuned
just as the title, due to the top mount inter-cooler setup on the 3sgte, is the GT4 style hood required for optimal performance? yes, if you go with a TMIC. The GT4 hood is functional for TMIC. No, its not. The hood has nothing to do with the intercooler, and is not needed for a 3sgte swap. The only benefit to the hood is over all better engine bay cooling, and it makes for a nicer looking car. isn't that the same as optimal performance? the question was required for optimal performance, not if its required for a swap. -------------------- THIS IS WHERE WE HOLD THEM!
just as the title, due to the top mount inter-cooler setup on the 3sgte, is the GT4 style hood required for optimal performance? yes, if you go with a TMIC. The GT4 hood is functional for TMIC. No, its not. The hood has nothing to do with the intercooler, and is not needed for a 3sgte swap. The only benefit to the hood is over all better engine bay cooling, and it makes for a nicer looking car. isn't that the same as optimal performance? the question was required for optimal performance, not if its required for a swap. Yes, but its not at all functional for the intercooler. Is it a better hood? Yes Is it needed for a swap? No -------------------- 15PSI - 30MPG - Megasquirt Tuned
![]() Enthusiast ![]() Joined Feb 6, '08 From Latvia Currently Offline Reputation: 0 (0%) ![]() |
just as the title, due to the top mount inter-cooler setup on the 3sgte, is the GT4 style hood required for optimal performance? omg, dont mess his head up! it depends what type of intercooler you choose!! if its air-to-air IC from regular ST185 or Caldina, then you HAVE to use IC that sucks air inside and through the intercooler!!! otherwise you would kill your engine as soon as it warmed up and you gave it a full throttle pull! if its water-to-air intercooler from st165, st185 CS/RC or ST205, you can live without it the bonnet. but its not optimal, since the vent on the st205 bonnet is to suck air out of the car. otherwise there would be a lot of pressure in the enginebay and both IC front water cooler and engine radiator would have very little air flow to cool down and you would soon see some cooling problems! in short: air-to-air intercooler - MUST USE bonnet with reverse scoop like st185 (and all subaru cars) water-to-air = st205 bonnet! -------------------- 1994 MR2 SW20, 1990 Celica ST185, both 3SGTE
turbo celica | celica club .eu | celica gt4 | imports | Toyota GT 86 | Scion FR-S | Subaru BRZ |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 29, '07 From Philly Currently Offline Reputation: 11 (100%) ![]() |
just use a front mount intercooler either way, unless you are going with a 3rd gen, i would suggest keeping the water to air.
i CAN however tell you this, since i swaped i have always ran a FMIC. at first i had the ST205 hood on my car and it cooled the engine bay down significantlly. when i put the stock hood back on, and ran the car for a while, i could not even touch the strut bar because it was so damn hot. that gt-4 hood is very functional, and either way it will pull cooler air into the bay. It is not NEEDED to do a swap, as you can see many people running stock hoods with swaps, but i would highly suggest either running a FMIC, W2A, or either one with the gt-4 hood. -------------------- ![]() I"M NOT A TOYOTA FAN, IM A FANATIC 1984 accord hatch 5 speed (T-Belt)-Junkyard 1991 VDUB jetta wolfsburg Ed. 5 speed (clutch)-junkyard 1988 Dodge Aries K (sold) 1969 Chevy El camino - Traded for celica 1991 Dodge Daytona-Traded for Celica 1988 Chevy Camaro-Work in Progress 1989 Ford Mustang LX 5.0 - For Sale 1995 Toyota Celica-Work in Progress |
it does not "pull air in"
its made to allow air to escape. only the snorkle pulls in air, and that is meant to flow into the upper timing belt cover. -------------------- Former Team 5SFTE pro member ;)
thanks for drilling this into the ground
![]() 3rd gen 3sgte with the W2A system. I was just concerned about running it with the factory hood until I could get the GT4 exterior |
Enthusiast ![]() Joined Sep 28, '09 From Washington, MO Currently Offline Reputation: 0 (0%) ![]() |
i'm also curious on this... wrc 3rd rev 3s-gte... my hood doesn't close all the way unless it's up on spacers at the hinges (as she is right now). how does one get the damn thing to close properly short of getting the gt-4 hood, or is that hood REQUIRED for proper fitment with the oem w2a intercooler?
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 11, '08 From Auckland, New Zealand Currently Offline Reputation: 0 (0%) ![]() |
forget the hood, to you guys its all aesthetics. it comes from rallying where highly strung 350+ HP engines run at high power for long periods of time and engine bay heat becomes an issue.
Unless you plan on running your engine at 7000+ RPM with ultra stoich AFR's (on the brink of detonation with maximum ignition advance) and 22+ psi all day long then yeah you might have a heat problem. And no, no fitment issues. a 3 point strut brace sits higher than the charge cooler, yet every man and his dog has one, and only a handful have gt4 hoods. -------------------- Mike W
forget the hood, to you guys its all aesthetics. it comes from rallying where highly strung 350+ HP engines run at high power for long periods of time and engine bay heat becomes an issue. Unless you plan on running your engine at 7000+ RPM with ultra stoich AFR's (on the brink of detonation with maximum ignition advance) and 22+ psi all day long then yeah you might have a heat problem. And no, no fitment issues. a 3 point strut brace sits higher than the charge cooler, yet every man and his dog has one, and only a handful have gt4 hoods. sweet... well, after i replace my oil pissing turbo, i'll be sure to drop the hood back down then... anyone know where to get a cheap ct20b that's from an actual business (that's not dead already)? |
Lo-Fi Version | Time is now: February 23rd, 2025 - 9:35 PM |
