Adding another Battery, neone know how to add another battery |
Nov 17, 2003 - 5:02 PM |
Enthusiast Joined Jul 7, '03 From Calgary, Alberta, Canada Currently Offline Reputation: 0 (0%) |
I have a ps2 and like lots of other things like system and stuff...and i notice that my battery can't handle all of the power and a cap only works for like bass and doesn't really store battery and work like a battery so i decided to add another battery does anyone have any ideas??? like how to install another battery in the trunk like how i would wire it??? or do i need a new alternater or anything???
Nov 17, 2003 - 5:26 PM |
Enthusiast Joined Apr 19, '03 From Washington Currently Offline Reputation: 0 (0%) |
nope...just hook up your leads...in fact..you can run a hot wire from the trunk to your battery under your hood...
This post has been edited by Stealths95GT: Nov 17, 2003 - 5:26 PM |
Nov 17, 2003 - 6:38 PM |
Keep in mind that with a different battery setup, you may not be able to take your car to the track. I know my friend wasn't allowed to take his Civic with a re-located battery onto the track because he didn't have a kill switch on the back of his car and it wasn't bolted down.
Nov 17, 2003 - 9:00 PM |
so if i just hooked up the batteries and i turned off my car would everything still be turned off that is hooked up to the extra battery?? and would the extra battery still be recharged by the alternater??? or will it just die after awhile???
Nov 17, 2003 - 9:01 PM |
not sure...i would think so..but i would just make a switch for that problem
Nov 18, 2003 - 4:05 PM |
so no one knows whats going on when u add another battery or no one knows how??
Dec 6, 2003 - 11:07 PM |
Enthusiast Joined Jun 21, '03 From Pennsylvania Currently Offline Reputation: 3 (100%) |
You can do that, connect both battery + to each other and both - to each other that way you get on big 12 volt battery. If you hook + to - and cross the leads you will end up with 24 volts! the alternator will charge the other battery too but the alternator is not designed to do that so you should get a bigger one to put more juice back into the batteries!
Lo-Fi Version | Time is now: January 18th, 2025 - 10:02 PM |
