![]() Enthusiast ![]() Joined Feb 3, '03 From Maryland Currently Offline Reputation: 0 (0%) ![]() |
Anyone by any chance have or know the mr2 wire diagram. My friend is trying to install a head unit and the wiring harness he bought from best buy doesnt fit right
thx |
i just figured out that they are the same as the celica
anyone have the celicas wiring diagram pics and such? |
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Jul 12, '03 From Chatham, Ont Currently Offline Reputation: 0 (0%) ![]() |
Ive got the repair manual with all the wiring diagrams, but no scanner, maybe theres a specific part I cold type out for you? you just need to know the order of the wires in the harness? dont you just match up the colors?
Enthusiast ![]() ![]() Joined Dec 19, '02 From West of Atlanta Currently Offline Reputation: 1 (100%) ![]() |
I posted this a while ago:
Power Connections Constant 12+ Blue/Yellow Switched 12+ Gray Ground Brown Power Antenna Black/Red and Pink/Blue connect both wires to the radio's remote wire. Illumination Green Speaker Connections Front/Right + Light Green Front/Right - Blue Front / Left + Pink Front / Left - Purple Rear / Right + Red Rear / Right - White Rear / Left + Black Rear / Left - Yellow Uppitycracker: you can't just match up the colors. Car makers use whatever colors they want the aftermarket companies settled on "standard" coloring but even then you should double check. |
Lo-Fi Version | Time is now: February 23rd, 2025 - 3:07 AM |
