> Shaving the Toyota emblem on bumper
post Jun 28, 2010 - 9:04 AM
HectortheRican
Joined Dec 26, '09
From Albuquerque, NM
I'm thinking about shaving the emblem on the front bumper I'm about to paint. What would be the best way to do this?
June '12 COTM
'95 AT200
post Jun 28, 2010 - 9:52 AM
conus00
Joined Jul 10, '08
From Tampa, FL
I've just shaved them on mine.
(1) Pop the emblem off (it's being held on two studs and little glue). Mine came off very easily.
(2) Either get old soldering gun and piece of polyurethane and "weld" the holes shut or take a piece of polyurethane and (using some very good glue) glue the pieces on the inside side of the bumper.
(3) Bondo over the welded holes and sand with (max) 240 grit
Then you are ready to paint.
If you skip step (2) the bondo WILL sink over the time and you will have two dimples in your bumper
Hope this helps.
'94 ST
Lo-Fi Version Time is now: February 13th, 2025 - 12:20 PM
