> Rotor size, ST vs GT
post Nov 18, 2003 - 3:13 AM
Neipas09
Joined Sep 5, '02
From Phoenix, AZ
I'm goin to buy some drilled/slotted rotors and i was wonderin if there was any difference in size between the GT and ST. Just curious cause i see rotors on ebay all the time for the GT but never for the ST.
post Nov 18, 2003 - 7:23 PM
yep
Joined Jun 24, '03
From MD
You may want to upgrade to rear wheel disc brakes first, if you haven't already.
This post has been edited by yep: Nov 18, 2003 - 7:24 PM
post Nov 19, 2003 - 12:03 AM
SpedToe169
From Dallas, Tx
They are most definitely different, but not by much. Best bet is to get the ST front brakes, and the GT rear disks. This is the best compromise between weight and braking power. This setup will work fabulously on anything with less than 300hp. Past that point you're going to need to go full custom and get some real brakes.
Lo-Fi Version Time is now: December 1st, 2024 - 6:49 AM
