Engine Stutter(oil on plugs) |
Jun 28, 2010 - 12:48 PM |
Enthusiast Joined Jun 28, '10 From kansas city Currently Offline Reputation: 0 (0%) |
I was driving my celica yesterday and it started stuttering going down the highway. I checked the distributor and rotor..both were in terrible condition so i replaced them. That did not work so i went on to check the plugs... the 1 and 4 cylinder plugs had oil on them. I replaced the tube seals and bought new plugs. The car ran fine for about and hour and then started stuttering again. At low rpms the stutter is hardly noticeable. But as I accelerate or cruise down the highway I can easily tell it's stuttering. I'm trying to keep myself from taking it to the toyota dealership and dropping a ton of money on it that way. Any ideas?
thanks |
Jun 28, 2010 - 12:55 PM |
Plug wires, proper plug gapping
Buy oem wires. -------------------- 1991 MR2 - T-tops - Crimson Red - Gen3 3SGTE - Lots of money
Jun 28, 2010 - 1:05 PM |
Plug wires, proper plug gapping Buy oem wires. Ill give the wires a shot. Though I feel teh plugs are fine. I purchased ngk iridiums. Didnt mess the with plug gapping at all though. Going to replaced the wires and run some seafoam through it this evening and see if that works. Thanks |
Jun 28, 2010 - 4:07 PM |
Enthusiast Joined Jun 18, '08 From Monaghan, Eire Currently Offline Reputation: 1 (100%) |
Rocker cover gaskets?
I had oil leaking into my plugs via the inner rocker cover gasket. Cheap fix, new gaskets around 20 clams. T |
Jun 28, 2010 - 4:35 PM |
But you're 3sge. I assume this is 5sfe related.
You need to pull the plugs and gap them. They don't come gapped. There is a gap specified by toyota. IIRC it is .410. I'll consult the BGB when I get home. As for oil on the plugs - my #3 plug has a small amount of oil on it, but it does not studder. Edit: could also be fuel related. Replace your fuel filter and have your injectors checked. If you can do without your car for a few days you can ship your injectors off to witchhunter performance for cleaning and repair. And go rent a timing gun and check that too. Your timing might be off. This post has been edited by 95CelicaST: Jun 28, 2010 - 4:42 PM -------------------- 1991 MR2 - T-tops - Crimson Red - Gen3 3SGTE - Lots of money
Lo-Fi Version | Time is now: December 3rd, 2024 - 10:05 AM |
