> No A/C - button blinks
post Jun 29, 2010 - 6:45 AM
speed-CCNP
Joined Mar 11, '09
From Baltimore, Maryland
Hi all,
My A/C compressor is not staying on. I press the A/C button and I hear it click like it's engaging but it cuts on for a few seconds then the A/C button blinks.
I installed a new A/C relay, condenser, evaporator, and compressor. I took it to a shop to have it changed and its holding pressure.
I'm not sure what to try. Any thoughts by the group?
Thanks
- speed-CCNP   No A/C - button blinks   Jun 29, 2010 - 6:45 AM
- - Smaay   the AC exciter (or whatever its called) is behind ...   Jun 29, 2010 - 8:45 AM
|- - nics   QUOTE (Smaay @ Jun 29, 2010 - 6:45 A...   Jun 29, 2010 - 11:57 AM
- - AMCMoe   On the passenger side, get on the floor and look u...   Jun 29, 2010 - 4:05 PM
|- - nics   QUOTE (AMCMoe @ Jun 29, 2010 - 2:05 ...   Jun 29, 2010 - 5:13 PM
|- - speed-CCNP   I found it and it was connected but I might have a...   Jun 29, 2010 - 8:54 PM
- - Mr_Tee   There is a switch on the compressor, you might wan...   Jul 1, 2010 - 10:25 AM
- - stephen_lee   ok some things to check to help me help you: doe...   Jul 1, 2010 - 11:20 AM
|- - nics   QUOTE (stephen_lee @ Jul 1, 2010 - 9...   Jul 1, 2010 - 11:27 AM
||- - stephen_lee   ur probly over charged. check the low pressure sid...   Jul 1, 2010 - 5:38 PM
|- - speed-CCNP   QUOTE (stephen_lee @ Jul 1, 2010 - 12...   Jul 2, 2010 - 8:11 PM
- - st18   i work for a toyota delership and most of the time...   Jul 3, 2010 - 2:24 PM
- - lagos   QUOTE (speed-CCNP @ Jun 29, 2010 - ...   Jul 3, 2010 - 2:37 PM
- - b22ri22an   when i first got my celica mine did the same thing...   Jul 5, 2010 - 9:36 AM
- - erahman85   I have the same problem with my car. After the swa...   Jul 5, 2010 - 11:19 PM
- - Malhar95   Got the same problem, but the wires seem to be cut...   Jun 10, 2013 - 7:04 PM
- - RabidTRD   Another thing that will cause the light to flash i...   Jun 10, 2013 - 10:35 PM
|- - Malhar95   QUOTE (RabidTRD @ Jun 10, 2013 - 10...   Jun 11, 2013 - 11:59 AM
|- - marblesmike   QUOTE (RabidTRD @ Jun 10, 2013 - 11...   Jul 16, 2013 - 10:08 AM
- - richee3   How did those get cut?! The herbed should be l...   Jun 11, 2013 - 2:00 PM
|- - Malhar95   QUOTE (richee3 @ Jun 11, 2013 - 2:00...   Jun 11, 2013 - 4:36 PM
- - Malhar95   Opened the glove box. Looks like those two wire se...   Jun 28, 2013 - 8:22 PM
- - trdproven   older toyotas had the problem when it rains heavy ...   Jul 1, 2013 - 7:51 PM
|- - Malhar95   QUOTE (trdproven @ Jul 1, 2013 - 8:5...   Jul 2, 2013 - 4:51 AM
- - Malhar95   Anyone have any advice? I was thinking if someone ...   Jul 8, 2013 - 9:05 AM
- - richee3   Yes, it's the same belt.   Jul 16, 2013 - 11:17 AM
- - chillywilly   Hello sir I read your article I agreed with your p...   Jun 26, 2015 - 5:38 AM
Lo-Fi Version Time is now: December 14th, 2025 - 12:17 PM
