2 Pages V  < 1 2
> No A/C - button blinks
post Jun 28, 2013 - 8:22 PM
Malhar95
Joined Jul 5, '09
From Katy/houston
Opened the glove box. Looks like those two wire sets are supposed to be connected but where does the other part of the harness go?
I looked to see if the wires from under the hood are coming inside and they seem to do...any advice?
I'm basically trying to figure out where the wire in red go?
post Jul 1, 2013 - 7:51 PM
trdproven
Joined Aug 2, '05
From Guam
older toyotas had the problem when it rains heavy and you just have to repress the button.
another thing to look at is your a/c clutch.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Jul 2, 2013 - 4:51 AM
Malhar95
Joined Jul 5, '09
From Katy/houston
QUOTE (trdproven @ Jul 1, 2013 - 8:51 PM) *
Ill search about the clutch but I still have to connect the wires...
I think it's the one that comes from the engine bay harness but the problem is that the person who did the swap didn't use the factory place (passenger side firewall) area to bring them in.
Anyone have the wiring diagram of the ac? I looked at my other celica it's the part that connect to the switch that is cut in the picture and that switch/harness has 3 wires going back the the engine
I need the diagram to see where those wires go so I just rewire it
post Jul 8, 2013 - 9:05 AM
Malhar95
Joined Jul 5, '09
From Katy/houston
Anyone have any advice?
I was thinking if someone can tell where the wires go I rewire it all new directly from that harness to wherever they go in the engine bay
I really need ac in the Texas heat so any help appreciated
post Jul 16, 2013 - 10:08 AM
marblesmike
Joined Jul 8, '13
From NJ
QUOTE (RabidTRD @ Jun 10, 2013 - 11:35 PM) *
Another thing that will cause the light to flash is when the compressor gets wet, like from a puddle, and the belt slips momentarily. I've had that happen a couple times and just shut it off then on again and it was fine.
Same here. Turning it off for a minute and turning it back on again fixes it. I also just had my alternator go, so it might have been related to that. Is the belt on the alternator the same as the A/C one? Noob question, I know.
post Jul 16, 2013 - 11:17 AM
richee3
Joined Jun 29, '08
From Denver
Yes, it's the same belt.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Jun 26, 2015 - 5:38 AM
chillywilly
Joined Jun 20, '15
From Willyhvac123
Hello sir
I read your article I agreed with your problems. I will do something for you. If you give me one chance then I will repair your AC button. It’s very easy way to shutout AC problem. I know very well what to do in case to repair AC.
2 Pages V  < 1 2
Lo-Fi Version Time is now: December 14th, 2025 - 4:41 PM
