> Need helping removing the EGR valve, How do you disconnect the EGR valve at the bottom?
post Jul 4, 2010 - 9:09 AM
QuadCannons
Joined Jun 27, '10
From New York, NY
I can't get a wrench into the small area where the metal pipe screws onto the bottom of the EGR valve. How are you guys doing it?
post Jul 4, 2010 - 9:19 AM
rave2n
Joined May 29, '09
From Gainesville, FL
I was unable to remove that way.
I had to remove my throttlebody, and remove it from the block via the pipe.
Then I took a mapp gas torn to the bolt, and it twisted right off.
post Jul 4, 2010 - 10:06 AM
i remove the throttle body, and use an adjustable wrench.
post Jul 4, 2010 - 1:27 PM
hatchy_gt-s
Joined Jan 16, '07
From covington, KY
buy a set of these, they make life so easy
I got mine from snap-on but craftsman makes them to, their like 4in total in length.
This post has been edited by hatchy_gt-s: Jul 4, 2010 - 1:29 PM
post Jul 4, 2010 - 1:32 PM
Johnnyny
Joined Apr 28, '09
From York pa
i used a regular socket wrench no problem at all
post Jul 4, 2010 - 5:29 PM
QuadCannons
Joined Jun 27, '10
From New York, NY
Using or knowing what wrench to use isn't the problem. I can't get my arm and the wrench into that space to loosen the nut.
Where is the throttle body and are there any guides to removing it?
post Jul 5, 2010 - 12:21 AM
hatchy_gt-s
Joined Jan 16, '07
From covington, KY
You asked what people used/did thats what I used/did. Im not saying buy a set just for this, they're also quite handy for other jobs.
The throttle body is the part that bolt onto the intake where you throttle cable is, it has 4 12mm bolts on the back side.
The whole on the intake manifold is where its bolted to.
post Jul 5, 2010 - 11:00 AM
QuadCannons
Joined Jun 27, '10
From New York, NY
Thanks for pointing out the throttle body.
Are you saying that with those short wrenches, you were able to loosen the EGR valve without having to remove the throttle body?
post Jul 5, 2010 - 11:14 AM
rave2n
Joined May 29, '09
QUOTE (QuadCannons @ Jul 5, 2010 - 12:00 PM) *
Just remove the throttle body, its 2 bolts and 2 nuts. It will save you a bit of headache.
Its still a small space to work in, regardless of the shortness of the wrench. If you are already have trouble torguing it off, a smaller wrench is going to make it even harder. Your going to need leverage to get that beast off.
Lo-Fi Version Time is now: February 18th, 2025 - 9:51 PM
