94 ST engine into a 97 ST?, will i have any problems with this? |
Jul 4, 2010 - 2:25 PM |
Enthusiast Joined Oct 7, '09 Currently Offline Reputation: 8 (65%) |
just curious as to if i will run into any problems swapping in my 94 STs engine into my new 97 ST that unfortunately
has a blown engine? i'm hoping it will drop right in without anything really needed... i figured it would but i'm just making sure so i can be ready, i plan on doing it next week.. thanksss ! -------------------- NOVAKx17
2000 Eclipse GT- DD=== oil pump went blown up and sold 1997 Celica ST- swapped and sold 2004 Ford explorer xlt 4x4- totaled 1997 Celica Convertible GT- Going Topless (; (18:32:21) yarik83: axel has a sensitive wife. i hear she used to be a lesbian and then became ferdi ( PARTING OUT A GT COUPE http://www.6gc.net/forums/index.php?showtopic=88592 ) |
Jul 4, 2010 - 2:44 PM |
Enthusiast Joined Apr 28, '09 From York pa Currently Offline Reputation: 3 (100%) |
possible emmision problem and wiring because of the change from obd1 to obd2
Jul 4, 2010 - 2:47 PM |
Okay... this may be the dumbest question of the year so far... but what exactly does obd1 and obd2 mean?
i'm figuring it has something to do with the exhaust ? thanks -------------------- NOVAKx17
Jul 4, 2010 - 2:50 PM |
http://en.wikipedia.org/wiki/On-board_diagnostics should answer your question
Jul 4, 2010 - 2:54 PM |
hmmm.. i kinda get it.. but it kind of amazes me that its going to make such a big deal in the swap..
Jul 4, 2010 - 3:08 PM |
Enthusiast Joined Oct 10, '06 From Greensburg,PA Currently Offline Reputation: 27 (94%) |
obdII adds a whole bunch of sensors to the engine, it also uses different sensors to be more specific so that it can store the data that is needed for the emissions and such... unless you strip the engine down to the bare block and head, an OBDII engine in an OBDI car is useless... its definitely possible but it may be easier to find an OBDI 7afe (before 1996)
-------------------- Breaking Axles...
Jul 4, 2010 - 3:18 PM |
blah that sucks... i didn't think it'd be all that bad considering that i just want to run it in the 97 until i can afford a swap without bankrupting myself.
Jul 4, 2010 - 5:04 PM |
these guys are making seem like its a lot bigger deal than it is.
any time you swap diffrent year engines, always use the accessories off of the motor your pulling out. (IE distributor, throttle body, coolant neck, ect.) once you do that, its a straight swap, no big deal at all. -------------------- Former Team 5SFTE pro member ;)
13.6@108MPH, 5SFTE Powered |
Jul 4, 2010 - 5:05 PM |
these guys are making seem like its a lot bigger deal than it is. any time you swap diffrent year engines, always use the accessories off of the motor your pulling out. (IE distributor, throttle body, coolant neck, ect.) once you do that, its a straight swap, no big deal at all. wow, thanks man... so just making sure i get this straight... since i'm putting the 94 engine into the 97 shell, i should put all the accessories from the 97 engine onto the 94 engine? -------------------- NOVAKx17
Jul 4, 2010 - 10:49 PM |
Enthusiast Joined Nov 16, '06 From Findlay,Oh Currently Offline Reputation: -1 (33%) |
these guys are making seem like its a lot bigger deal than it is. any time you swap diffrent year engines, always use the accessories off of the motor your pulling out. (IE distributor, throttle body, coolant neck, ect.) once you do that, its a straight swap, no big deal at all. wow, thanks man... so just making sure i get this straight... since i'm putting the 94 engine into the 97 shell, i should put all the accessories from the 97 engine onto the 94 engine? yes you got it bud!!! |
Jul 4, 2010 - 10:51 PM |
okay GREAT! i'm hoping to get this started either tomorrow or tuesday..
i'm waiting on my engine stand to get back from my cousins, since they borrowed it and "forgot" to bring it back, but i finally managed to get ahold of them today and they said they'd bring it over!! -------------------- NOVAKx17
Jul 5, 2010 - 9:22 PM |
ya. the dizzy & oil pump are different for sure.
Lo-Fi Version | Time is now: January 7th, 2025 - 11:44 AM |
