![]() Enthusiast ![]() Joined Oct 24, '09 From New Zealand Currently Offline Reputation: 0 (0%) ![]() |
![]() I need the part above the reinforcement bar,(highlighted)support sub assy. part number 53205-20070 ![]() does it have some bolts on it or need to be cut from the shell/?? can any1 tell me the whole thing I need for the support sub assy?im not good at welding things together dont want cut the part from shell This post has been edited by zd1818: Jul 5, 2010 - 4:03 AM |
![]() I need the part above the reinforcement bar,(highlighted)support sub assy. part number 53205-20070 ![]() does it have some bolts on it or need to be cut from the shell/?? can any1 tell me the whole thing I need for the support sub assy?im not good at welding things together dont want cut the part from shell you need the upper bumper support,(the upper part you have circled) not the radiator support. there are a handful of spot welds that hold it on, i've done the conversion a few times now, although its not needed to install the gt-4 bumper, you can use a few bodywashers between the bumper and bumper support in the middle where the raised section of the gt-4 bumper attaches. the upper bumper support is ~50$ new from toyota, i cant imagine a shop charging you more than 100$-150$ or so to install it. -------------------- Former Team 5SFTE pro member ;)
Lo-Fi Version | Time is now: February 22nd, 2025 - 10:47 AM |
