2 Pages V  < 1 2
> 97 5s into a 95 5s
post Jul 8, 2010 - 11:16 AM
GriffGirl
Joined Feb 7, '07
From Portland, Oregon
The dash harness I'm sending you I'm almost positive is from an OBDII GT. Are you using the engine harness I sent you too? Remember, they came from the same car. (too bad I don't have the ECU from it too, you'd be SET!)
So really it sounds like all you're missing is the ECU. Between the two harnesses coming from me, the rest should totally be plug and play.
post Jul 8, 2010 - 11:17 AM
JuMPiiN
Joined Nov 10, '09
From Louisiana
I hope so! The harness I'm getting with the engine is obd2 and so is the ecu. Maybe I'll get lucky lol.
post Jul 8, 2010 - 11:48 AM
yeah man, its all in there..
post Jul 8, 2010 - 4:48 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
ya no kidding. i live in s. tx and its effin HOT
post Jul 8, 2010 - 4:59 PM
richee3
Joined Jun 29, '08
From Denver
If Michelle is sending you an OBD II dash harness, then you should be all set. Your engine, wiring harness, and ECU will all work together and if you replace your dash harness with an OBD II dash harness, I can't think of anything else that would be an issue. I'd say you're finally good to go, and you deserve it! You've been put through a nightmare so far. It'll be great to see your car back on the road again.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Jul 8, 2010 - 5:30 PM
JuMPiiN
Joined Nov 10, '09
From Louisiana
You have no idea ! I went to the shop where my car was at for a month, and luckily he still had the harness I bought from Griff so I have it I'm so stoked.
2 Pages V  < 1 2
Lo-Fi Version Time is now: December 11th, 2024 - 7:05 PM
