> Engine trouble- drove 1 block then motor shut off, 2nd gen 3sgte
post Jul 7, 2010 - 4:39 PM
eggman40
Joined Aug 17, '04
From California
I pulled over, checked for loose wires and IC pipes. Tried starting it up again and it just turned over but didnt sound like it wanted to fire... like there was either no fuel or no spark. Waited about 3 mins. tried again and it fired up no problem... no engine lights either. Could it be the Injector resistor pack? what else should i check? thanks!
post Jul 7, 2010 - 5:55 PM
GriffGirl
Joined Feb 7, '07
From Portland, Oregon
check to make sure your battery cables are connected tightly... simple, I know, but I've seen it before.
Otherwise, sounds like it could be anything ranging from something ignition related to maybe your fuel pump failing.
post Jul 7, 2010 - 6:53 PM
Put a paper clip between B+ and FP and see if you hear the fuel pump come on and if the car starts that way.
Lo-Fi Version Time is now: November 29th, 2024 - 11:47 AM
