> im going to paint my brake caliper, and drum in the back... what paint?
post Nov 17, 2002 - 8:06 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
what paint should i use to properly get the job done and stay looking nice.
i mean no chiping or burning off. thx
post Nov 17, 2002 - 8:13 PM
boosted_K2
Joined Aug 30, '02
From Michigan
well to be able to spray it and forget about it, get the actual caliper paint, they got it at alot of autostores and at like nopi etc... i use engine enamel and just some automotive clear coat, it works fine! alot cheaper also, i used lime green at 1st but w/o the clear coat, it started wearing away and looked like a pea green, kinda hideus... i then stripped em and painted em a dark blue and used clear coat, looks great and never had to repaint em yet. i probably will after winter...
No but I don't buy it
Cause I'm...
post Nov 18, 2002 - 4:03 PM
JWalk1818
Joined Aug 30, '02
From North Carolina
Well I just used 500 degree paint for them , but you can get up 1200. I need to do mine againg but they have lasted 2 years!
99 Toyota Tacoma
post Nov 18, 2002 - 8:07 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
i did it taday i use engine enamel that is for 500 degree so that worked good i did two coats.
post Nov 18, 2002 - 10:13 PM
boosted_K2
Joined Aug 30, '02
From Michigan
i used 500 the 1st time, 1200 the second, decided i really didnt wanna mess with it again for a while...
Cause I'm...
post Nov 18, 2002 - 10:46 PM
JWalk1818
Joined Aug 30, '02
From North Carolina
Yea if I ever do mine agian im gogin to use 1200 degree, but it really hasent burnt off jsut chipped from peeps hititng it!
99 Toyota Tacoma
post Nov 22, 2002 - 7:12 PM
CDNSLEEKA
Joined Sep 16, '02
From Yarmouth,N.S Canada
i only used engine enamel 500... worked fine..clearcoat is a good idea!! smile.gif
post Nov 23, 2002 - 11:28 PM
NEVERSTOP
Joined Nov 4, '02
From Davenport Iowa
Be sure that you are using automotive primer... will help with the chipping
post Nov 29, 2002 - 12:32 PM
Phr0z3n664
Joined Oct 20, '02
From Covington, La
biggrin.gif I used the Engine Enamel and sprayed about 5 coats, w/ no clear coats and it's perfect, only thing is that my calipers are bright green and they happen to attract the brake dust.
Lo-Fi Version Time is now: November 23rd, 2024 - 10:55 PM
