> 2nd Gen 3SGTE into 6th Gen Celica Pics
post Jul 16, 2010 - 6:34 PM
Dr_Tweak
Joined Mar 31, '04
From Summerville, SC
Hi guys,
Little update on one of the projects in the shop, this is a 6th Gen that's had a 3SGTE bolted into it for a few years now, because of various issues the owner wasn't able to find someone to get it finished, until it ended up here.
What it looked like when it showed up:
Cleaning process....
We checked the timing belt and found both cams to be a tooth off, so we had to redo that.
Cleaned up the wiring harness...
Details: Fuel filter rotated so that the banjo to AN adapter can make use of the stop on the filter when tightening the bolt. Wiring harness secured with cushion clamps where needed.
Details: Stainless line covered with glue-lined heatshrink where it gets close to the wiring harness. This will prevent any chance of the stainless braiding wearing away at the loom.
True cold air intake
Stainless line where it connects to the rail.
Coil/igniter relocated off the firewall to clean things up. Also relocated the MAP sensor off the firewall and hid the resistor pack out of view.
True cold air intake, note that factory cruise control has been retained, with plenty of clearance between the bracket and the intake piping.
Another view of the cold air intake location.
Overall view. Engine is waiting on a new fuel pressure regulator and injector clean/balance/flow test before starting.
Click here to see my swaps
drtweak@phoenixtuning.com
post Jul 16, 2010 - 6:37 PM
rave2n
Joined May 29, '09
From Gainesville, FL
post Jul 16, 2010 - 7:37 PM
Nice and clean install. Props!
post Jul 16, 2010 - 9:04 PM
Cuts_the_Pilot
Joined Dec 15, '02
From Tasmania(Australia)
good job, not having the coil map etc on the firewall clears things up.
what you going to do as far as feeding air to the tmic goes?
ST205 Group A Rallye GT-Four, #61 of 77............600hp GT3582r
GRX133 Toyota Mark X 350s
post Jul 17, 2010 - 11:04 AM
Dr_Tweak
Joined Mar 31, '04
Thanks guys. As for the intercooler I'm still hoping the owner will spring for a front mount setup.
post Jul 17, 2010 - 11:10 AM
Masterful work.
post Jul 17, 2010 - 11:16 AM
Stambo
Joined Apr 23, '08
From Muskego,Wi
Looks great tweak!
By the way great work on the wiring harness you did for me! Started right up!
2nd Gen 3s-gte.... It lives!
97celiman
post Jul 18, 2010 - 6:29 AM
lookin good tweak!
post Jul 18, 2010 - 4:42 PM
SoDo
Joined Dec 16, '07
From Chicago, IL
Good stuff!! Hopefully your customer appreciates your work.
1999 Celica GT Hatchback
post Jul 19, 2010 - 9:31 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
awesome work Josh! where did you find that Banjo to -6 is it? what a cool fitting!
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Jul 19, 2010 - 4:32 PM
QUOTE (Smaay @ Jul 19, 2010 - 10:31 AM) *
those fittings are available from most of the manufactuers...earls, aeroquip, ect all make them.
post Jul 20, 2010 - 10:53 AM
Dr_Tweak
Joined Mar 31, '04
Thanks for your kind comments. After giving the fuel problem some more thought I was suspicious about the fuel pump installation. We pulled it out and found this:
Looks like they used a piece of heater hose for the fuel line. For those that don't know, fuel and oil will eat right through a heater hose. So the pump was pushing a little bit of fuel up to the rail but not enough to open the regulator. We redid the fuel pump install...
And then after resuscitating the injectors, it started up on the first try smile.gif
post Jul 20, 2010 - 1:10 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
WTF is that? that is the worst fuel pump hack job i have ever seen. im suprised wires didnt melt. good thing you checked that.
post Jul 29, 2010 - 9:53 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
updates?
post Jul 29, 2010 - 9:58 AM
Dr_Tweak
Joined Mar 31, '04
Owner doesn't have fund for any more work on the car for now, so with the engine finally running and the car able to drive, he's taking it home until he can save up for front mount, exhaust, etc.
-Doc
post Jul 29, 2010 - 10:53 AM
DEATH
Joined Dec 19, '07
From tx
Nice work as usual Tweak! [within the budget constraints of course]
Need to ditch that BBQ Grill ASAP [But I'm not telling you anything you didn"t already know tongue.gif
SUSP: Tein/Bilstein/SusTech/
EXT: WRC/TRD/404
Slow down Paul Walker.
Lo-Fi Version Time is now: December 1st, 2024 - 9:55 PM
