> Throttle body coolant hose bypass?, anyone done this?
post Jul 16, 2010 - 8:06 PM
blu94gt
Joined Mar 23, '05
From Kansas City
So I was talking with a friend at work about cars, and we were talking about pulling my throttle body to clean it since I've had some issues lately, but he said while I have it off I should leave the coolant hoses that go to it disconnected and that will help reduce intake air temperature.
Any gains from doing this? Only thing I can find online is that it will cause problems during the winter, but even those reviews seem to be mixed.
1999 Celica GT
post Jul 16, 2010 - 8:35 PM
pittfirefighter
Joined Oct 10, '06
From Greensburg,PA
what coolant lines?
Breaking Axles...
post Jul 16, 2010 - 8:39 PM
Johnnyny
Joined Apr 28, '09
From York pa
QUOTE (blu94gt @ Jul 16, 2010 - 9:06 PM) *
i know spider77 just did this im sure you will see gains but probably nothing too crazy
post Jul 16, 2010 - 9:01 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
if you have cold winters and high humidity, you might freeze your throttle open/closed. you're basically "decompressing" or reducing the pressure of the air as it passes into your intake... which causes quite a decrease in temp. if at all possible, put a valve on one of the coolant lines(or both), so you can open it and have functionality of the throttle defrost as Toyota intended if you ever have the 'frosting' issue.
Cuts_the_Pilot
Joined Dec 15, '02
From Tasmania(Australia)
i disconnected mine way way back when.
whats the lowest temp you get where you are (ie freezing)
the idea of it is to heat up a little wax pallet, this opens a valve and lets air into your engine so it idles cold. If your not in an overly cold climate then its not such an issue.
ST205 Group A Rallye GT-Four, #61 of 77............600hp GT3582r
GRX133 Toyota Mark X 350s
post Jul 16, 2010 - 9:08 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
im going to completely remove this system from my V6 swap as i live in south tx and it doesnt get cold here lol. cut the nipples and weld the holes closed.. may even put in an electric heater and do away with the heater core and the associated lines... we'll see
that idea was replaced with the IAC valve, an electronic control the does the same function
QUOTE (Cuts_the_Pilot @ Jul 16, 2010 - 9:01 PM) *
post Jul 16, 2010 - 10:23 PM
Spider77
Joined Jan 17, '08
From JB MDL, NJ
I just did this with my 5S last weekend. All I did was purchase two hose clamps (almost typed "clams"), and a 5/16 barbed brass connector. Took off the coolant lines, threw the hose clamps on either (by that I mean both) side, inserted barb connector, and tightened hose clamps. You could use a 3/8 connector, but I found it to be a bit too tight (as I couldn't get the hose flush). Now you could hook up valves and what not, but it only takes about 10 min to swap it back and forth, so whats the need? Unless your that lazy I suppose.
But really it isn't that hard to do. And when the weather here starts getting rough I'll just put it all back together and wait till it warms up enough.
post Jul 17, 2010 - 5:21 PM
blu94gt
Joined Mar 23, '05
From Kansas City
Thanks for the input guys. I think I'll at least give it a try since it's been so hot here lately.
Winters here get pretty cold, every now and then we dip into the single digits, but the air is usually very dry (I get a lot of static shocks on things all over the place). I've read about some people having issues, and other people going for years driving in the snow with the lines bypassed. Most likely I'll put a valve in the line to make it easy to switch.
1999 Celica GT
post Jul 17, 2010 - 6:34 PM
I've had mine bypassed on my 3s for a few years now.
No problems in any weather.
post Jul 17, 2010 - 6:37 PM
Spider77
Joined Jan 17, '08
From JB MDL, NJ
See, it must be one of things that everyone does, but no one talks about......
post Jul 19, 2010 - 10:32 AM
HectortheRican
Joined Dec 26, '09
From Albuquerque, NM
QUOTE (Spider77 @ Jul 17, 2010 - 6:37 PM) *
Could you explain to me what this does, other than make the motor idle cooler?
June '12 COTM
'95 AT200
post Jul 19, 2010 - 1:56 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
lowers intake temp slightly. lower temp = denser air = more power. you gain a tiny amount of power (<1hp)
post Jul 19, 2010 - 1:58 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
it doesnt do anything. it removes the slight possibility of having warmer air from hot water flowing through it entering the engine. its purpose os to prevent the TB from freezing up in extreme cold. bypassing the TB just cleans things up a little
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Jul 19, 2010 - 2:01 PM
HectortheRican
Joined Dec 26, '09
Soo... how does it get bypassed?
June '12 COTM
'95 AT200
post Jul 19, 2010 - 2:05 PM
SleekCelica
Joined Mar 28, '10
From Columbia, South Carolina
Connect the two hoses directly to each other using a coupler, and 2 hose clamps, rather than connecting them to the TB.
1994 Celica GT, coupe, 5 speed.
Front strut brace, cherrybomb glasspack, intake.
post Jul 19, 2010 - 2:12 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
or just cap them off at the water neck
post Jul 19, 2010 - 2:17 PM
HectortheRican
Joined Dec 26, '09
I see. I guess if I decide to mess with it, I can ask Spider77. He's pretty close to me
June '12 COTM
'95 AT200
post Jul 19, 2010 - 4:19 PM
Spider77
Joined Jan 17, '08
From JB MDL, NJ
Yea he is, its real simple man.
post Jul 20, 2010 - 12:19 PM
blu94gt
Joined Mar 23, '05
From Kansas City
Working on capping them right now. Have the TB off the car, just finished cleaning it up, it was a MESS, I'd seen dirty TB's before but this was a really thick, chunky build up of stuff. No wonder I was having throttle sticking problems. Looks like I might make myself an oil catch can and someday clean my whole intake manifold too.
Should get it finished up pretty quick after I sit in the air conditioning for a bit, it's HOT out in the garage!
1999 Celica GT
post Jul 20, 2010 - 10:45 PM
f1yen
Joined Oct 29, '05
From Muskego, WI
I had mine bypassed; untill i had to engine swap
double male barb and 2 hose clamps
Celi made it though like 2 winters here in WI, sub zero quite a bit; I wouldn't worry about it too much.
Lo-Fi Version Time is now: November 23rd, 2024 - 7:40 PM
