> 3sge to 3sgte, turbo upgrade
post Jul 18, 2010 - 6:39 AM
celicaupto550hp
Joined Jul 18, '10
From aucks
I'm converting my 3sge celica to a 3sge with a gt30 turbo and the oil and water lines for this are becoming a problem where they are now all the other mods required are done but where are the best places to tap my oil feed/return and water feed/return lines to?
I can make a t section or a way of tapping onto the radiator hosing for inlet and outlets but would that be enough to?
And for the oil would it just be easier to run the oil feed line from the oil cooler and the return back into the sump tapped in with a 6,8 whatever sized an fitting is on the braided lines?
Disco Dave
post Jul 19, 2010 - 12:08 AM
malpaso
Joined Feb 3, '06
From Czech Republic (Europe)
Sad to say but... you will need someone with experience. Someone really good not just enthusiastic idiot that only thinks he can do it (reason why my 3SGE -> 3SGTE project failed last year). Good luck.
post Jul 19, 2010 - 2:42 AM
Rusty
Joined Nov 5, '07
From New Zealand
A NZ'er has buit a 3S-GE+T in plamy(?), TRDGT4 might have some info about it, since he knew the previous owner, and the new owner Missmonster still has it as far a I know.
post Jul 20, 2010 - 12:20 AM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
QUOTE (celicaupto550hp @ Jul 18, 2010 - 6:39 AM) *
IIRC the oil pan section is almost identical to the 3rd gen 3sgte minus the oil feed and return. Can you buy the 3sgte oil return fitting and see if it bolts up? I know KORacing has a AN fitting for the drain for the 3rd gen. For the feed you can simply get it from the head where the oil pressure sensor is.
For water lines you can do what 5sfte guys do and use the lines leading to the throttle body. The lines going to the throttle body is used to keep it warm in the winter.
94 Celica gt white (sold)
post Jul 24, 2010 - 12:51 AM
celicaupto550hp
Joined Jul 18, '10
From aucks
what about the 3sgte sump then wouldn't it just be easier to swap it out for the gte version?
Disco Dave
post Jul 26, 2010 - 11:40 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
Yep should be a direct bolt on.
Lo-Fi Version Time is now: November 27th, 2024 - 8:03 PM
