> Removing Motor and Tranny., CHANGED TITLE NAME ( read 1st post )
post Jul 18, 2010 - 8:31 PM
JuMPiiN
Joined Nov 10, '09
From Louisiana
Changed the title name so i didnt have to make another new thread.
So heres my question, how do i remove the axles connected to the tranny to pull out the engine and transmission. Me and my buddy already have everything disconnected except for the mounts of course.
We've taken off the AC Compressor, Alternator, Wiring harness, and all the vacume lines. Just need to removed the axles so we can pull the motor and tranny.
Please help lol i used the search button but just got a bunnch of people swapping engines and no how to remove axles lol.
This post has been edited by JuMPiiN: Jul 20, 2010 - 7:49 PM
post Jul 18, 2010 - 9:14 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
pulley puller haha
35-50$ at autozone or slightly cheaper at harbor freight
post Jul 18, 2010 - 9:23 PM
Yup, I just bought a 8" 3 jaw pulled from harbor freight for a stubborn 5s crank pully a few weeks ago.
Iirc it was ~18$
post Jul 18, 2010 - 9:27 PM
JuMPiiN
Joined Nov 10, '09
From Louisiana
I took some pics of the work so far. I cant get the bottem of the timing belt cover off either and i dont want to mess anything up. Me and one other friend are doing this, replacing the water pump, oil pump, and gaskets and seals, and timing belt and tensioner.
post Jul 18, 2010 - 9:34 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
what do you mean you can't get the lower cover off? you still have the crank pulley installed.
post Jul 18, 2010 - 9:36 PM
JuMPiiN
Joined Nov 10, '09
From Louisiana
no you think hints why i asked how to take the damn thing off.... which i know how to now.
post Jul 19, 2010 - 12:04 AM
JuMPiiN
Joined Nov 10, '09
From Louisiana
Still won't come off. I'm getting extremely aggravated.
post Jul 19, 2010 - 9:35 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
cant see your pics from work, i hope you have the engine out of the car. read my thread on rebuilding the 7A and my thread on turboing my 5S. i have tons of pics in there, maybe they can help you
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Jul 19, 2010 - 11:26 AM
JuMPiiN
Joined Nov 10, '09
From Louisiana
I checked your threads and none of the pics will load. And yes engine Is out the car.
post Jul 19, 2010 - 7:02 PM
JuMPiiN
Joined Nov 10, '09
From Louisiana
If i buy a Metal Headgasket, do i have to take anything to the machine shop or can i just put it on like any other normal head gasket, and also where exactly do I put my old head studs on the block in order to lift the engine.
Excuse my noobness. This is my 1st engine swap ive done by myself without any help.
post Jul 20, 2010 - 8:56 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
http://www.6gc.net/forums/index.php?showtopic=72502
pics work for me
post Jul 20, 2010 - 7:49 PM
JuMPiiN
Joined Nov 10, '09
From Louisiana
New title and question ! lol
post Jul 20, 2010 - 8:36 PM
Remy
Joined Jan 25, '06
From MN
Driver Side Axle Removal: http://www.6gc.net/forums/index.php?showto...;hl=driver+axle
Pass Side Axle you just unbolt it from the hub and bearing bracket it should just slide right off after that.
BTW if u search in the right spots you'll find the right answers lol....axle removal is in the suspension area yes it does matters where you search. smile.gif
"To Protect And To Serve The Wealthy" -POLICE
post Jul 20, 2010 - 8:37 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
the obv first step is remove the huge 30mm nut in the center of the hub
crowbar between axle and tranny to pop it out (exp on pass side, it bolts to a bracket on the block)
remove the 2 nuts & bolt under the hub (that hold the ball joint to the control arm) swing the hub assy away and push the axle out
post Jul 20, 2010 - 9:48 PM
JuMPiiN
Joined Nov 10, '09
From Louisiana
I havnt gotten To it quite yet. Figured I'd ask so I'd know what to do tmo. My buddy is arguing with me saying it would be easier to take out just the engine and leave the transmission. So tmo we should tackle that bridge. I'm just going to rename this thread and make it my rebuild/turbo 5s thread. Turbo will be in a few months tho.
post Jul 20, 2010 - 10:08 PM
lol, its easy to take the axles out, the driver side is more stubborn.
post Jul 21, 2010 - 10:21 PM
JuMPiiN
Joined Nov 10, '09
From Louisiana
Do I need a axle puller ?? I tried today and I'm scared imma break it off and then need another tranny.
post Jul 22, 2010 - 12:18 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
no. pry in the right place, itll eventually pop out. ive done this... almost 10x on my cars & friends cars. you will be ok
post Jul 22, 2010 - 5:03 PM
f1yen
Joined Oct 29, '05
From Muskego, WI
It's a circlip, so it will need a little motivation to move. just get a prybar under it, or both sides ( I believe hats how i did it last) Might want to drain your tranny fluid first.
Lo-Fi Version Time is now: February 21st, 2025 - 9:18 AM
