![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 26, '09 From Albuquerque, NM Currently Offline Reputation: 19 (100%) ![]() |
I've seen the vincent_doggy one, it looks neat and from what he says, better throttle response, but alas, I don't have the 3SGE
![]() -------------------- taking too long to mod since '09
June '12 COTM '95 AT200 |
![]() Moderator ![]() ![]() ![]() ![]() ![]() Joined Nov 5, '07 From New Zealand Currently Offline Reputation: 3 (100%) ![]() |
It wont fit the 7A, what would the intake spacer space out??. The 3S-GE uses ACIS in the intake system. You'd have to fit the 3S intake manifold up to the 7A motor, for it to work.
"aiming to increase the air capacity of the air surge tank around the quad throttle area. Simply by adding this part, torque and power increased across the rev range, with a peak of 10hp gained on Zero-1000's test vehicle!" -------------------- |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 17, '08 From JB MDL, NJ Currently Offline Reputation: 30 (100%) ![]() |
I think he was asking if it would be worth it to get one for the 7A custom made. Custom usually means money, so unless your doing it on your own, Id say probably not. Then there was the question of hood clearance....
I think he was asking if it would be worth it to get one for the 7A custom made. Custom usually means money, so unless your doing it on your own, Id say probably not. Then there was the question of hood clearance.... Yup, that was my question. Haha. It was just a random thought I had and wanted some feedback. Thanks! -------------------- taking too long to mod since '09
![]() Enthusiast ![]() Joined Jun 18, '08 From Monaghan, Eire Currently Offline Reputation: 1 (100%) ![]() |
Sorry to sound like a tool, but does this fit between the intake manifold and the head?
QUOTE (Spider77) I think he was asking if it would be worth it to get one for the 7A custom made. Custom usually means money, so unless your doing it on your own, Id say probably not. Then there was the question of hood clearance.... Fair enough, was pointing out that getting the spacer alone, would not improve throttle response HectortheRican wanted QUOTE (Tony-B) Sorry to sound like a tool, but does this fit between the intake manifold and the head? goes on the intake manifold, you take the top cover of your ACIS chamber and it goes there ![]() ![]() -------------------- |
Lo-Fi Version | Time is now: February 20th, 2025 - 1:51 AM |
