> cam problem, now with a picture!!!
post Jul 23, 2010 - 4:03 PM
pipes
Joined Apr 23, '08
From boston MA
hey anyone have problems with there aftermarket cams on a gen 3 3sgte? i seem to be running into some problems
This post has been edited by pipes: Jul 25, 2010 - 7:18 AM
post Jul 23, 2010 - 4:46 PM
QUOTE (pipes @ Jul 23, 2010 - 5:03 PM) *
what kind of problems exactly?
only problems i've ever read about is clearance issues in certain heads with certain cams...all on mr2oc of course.
post Jul 23, 2010 - 5:16 PM
pipes
Joined Apr 23, '08
From boston MA
QUOTE (presure2 @ Jul 23, 2010 - 5:46 PM) *
Hks 272. Ca.ms rubbibg on the oil passage exhaust side
post Jul 24, 2010 - 6:41 AM
QUOTE (pipes @ Jul 23, 2010 - 6:16 PM) *
are they the high lift ones?
IIRC those are the ones that need clearancing on certain heads.
i would run a search on mr2oc for more info.
post Jul 24, 2010 - 7:21 AM
pipes
Joined Apr 23, '08
From boston MA
I ran a search and I have a post can't really find anything
post Jul 24, 2010 - 7:31 AM
QUOTE (pipes @ Jul 24, 2010 - 8:21 AM) *
yea, i saw your post, and did a quick search as well...only thing i found was using gen3 high lift cams in a gen2 head.
got any pics?
is it somthing that you could clearance yourself with a dremel? or a major issue?
post Jul 24, 2010 - 7:46 AM
pipes
Joined Apr 23, '08
From boston MA
Right where the op switch is there is a passage that goes into the head I could shave it but I don't know if its actually safe to shave it there otherwise its gonna be time for a new head
post Jul 24, 2010 - 8:11 AM
QUOTE (pipes @ Jul 24, 2010 - 8:46 AM) *
i cant say for sure one way or the other, but i would guess as long as your not going to cut into an oil passage that delivers pressured oil, you would be fine grinding out some material.
post Jul 25, 2010 - 6:32 AM
pipes
Joined Apr 23, '08
From boston MA
anyone with a sure answer? kinda need to know by tomorrow so i can put this head back together....and put the cams up for sale
post Jul 25, 2010 - 8:59 AM
sorry i cant be more help man, hopefully the guys on mr2oc will have an answer for ya now that you posted up a pic.
i would imagine there would be enough material there for you to grind it out enough for the cam to clear...worse case, you could call jim, i know for sure he has at least a couple spares around from talking to him. wink.gif
post Jul 26, 2010 - 12:55 AM
Rusty
Joined Nov 5, '07
From New Zealand
have you got any more pictures, further out?
post Jul 26, 2010 - 8:31 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
i cant see the pic, but i have 272 in my built 3S-GTE......oh wait you said gen 3 head. call ATS. they might know the answer you are looking for
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
Lo-Fi Version Time is now: November 30th, 2024 - 5:57 PM
