![]() Enthusiast ![]() ![]() ![]() Joined Oct 7, '09 Currently Offline Reputation: 8 (65%) ![]() |
okay heres the deal... i've recently bought some dropzone 1.5" front and rear lowering springs and i've
heard you should get camber kits when you lower your car? 2 things... is it hard? and do you actually have to do it? i tried reading up on it on here but havne't had too much luck, when i searched camber kit, there were a ton of results but after looking through about 20 i had no luck ![]() thanks guys -------------------- NOVAKx17
2000 Eclipse GT- DD=== oil pump went blown up and sold 1997 Celica ST- swapped and sold 2004 Ford explorer xlt 4x4- totaled 1997 Celica Convertible GT- Going Topless (; (18:32:21) yarik83: axel has a sensitive wife. i hear she used to be a lesbian and then became ferdi ( PARTING OUT A GT COUPE http://www.6gc.net/forums/index.php?showtopic=88592 ) |
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Mar 8, '08 From Orlando, Florida Currently Offline Reputation: 14 (100%) ![]() |
dont really get what you are asking? is it hard to install the camber kit? No, its as simple as just replacing one bolt on the bottom of each strut.
Is it necessary? If you want your tires to wear properly, yes. If you desire negative camber, dont put it. This post has been edited by samir0189: Jul 26, 2010 - 12:50 AM -------------------- ◊◊◊ My F/S Thread! ◊◊◊
![]() Enthusiast ![]() ![]() Joined Jul 3, '09 From UT Currently Offline Reputation: 14 (100%) ![]() |
You shouldnt have to do anything for a 1.5" drop. I have Eibach Sportlines with a 1.5" on front and back. I didnt need anything changed when i had my alignment done. It came out fine.
You will most likely need to change your end links, though... (They go bad and often get torn up if you dont remove them correctly. Youll need allen wrenches and a 12mm wrench* I think... Dont quote me on that.) Be prepared for a minimum of $15 each for the Autozone ones. Twosrus ones are $60 + for a set if you decide to go to the aftermarket adjustable ones. |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 26, '09 From Albuquerque, NM Currently Offline Reputation: 19 (100%) ![]() |
You will most likely need to change your end links, though... (They go bad and often get torn up if you dont remove them correctly. Youll need allen wrenches and a 12mm wrench* I think... Dont quote me on that.) Be prepared for a minimum of $15 each for the Autozone ones. Twosrus ones are $60 + for a set if you decide to go to the aftermarket adjustable ones. Which are the endlinks? I'm pretty sure I know what you're talking about. -------------------- taking too long to mod since '09
June '12 COTM '95 AT200 |
I'll be lowering my Celi with Megan Racing coilovers soon, it won't be slammed. Probably 1.5" drop. Definitely no more than 2". Would I absolutely NEED to replace the endlinks? I don't do crazy driving, I just got the coils because my struts are dead and I wanted to lower my car anyway, might as well get the nice things. So they shouldn't be under extreme amounts of stress. This post has been edited by HectortheRican: Jul 26, 2010 - 10:59 AM -------------------- taking too long to mod since '09
I'll be lowering my Celi with Megan Racing coilovers soon, it won't be slammed. Probably 1.5" drop. Definitely no more than 2". Would I absolutely NEED to replace the endlinks? I don't do crazy driving, I just got the coils because my struts are dead and I wanted to lower my car anyway, might as well get the nice things. So they shouldn't be under extreme amounts of stress. Also, in relation to the OP, the fronts are camber adj and I bought the Eibach adj camber bolts for the rear. -------------------- taking too long to mod since '09
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 18, '05 From Calgary Currently Offline Reputation: 20 (100%) ![]() |
you dont necessarily need to replace the links. but for every two cars that required rear suspension work i've had to cut the links on one requiring me to buy a new pair of rear links. the allen key hole in the links are easily rounded.
you dont necessarily need to replace the links. but for every two cars that required rear suspension work i've had to cut the links on one requiring me to buy a new pair of rear links. the allen key hole in the links are easily rounded. Thanks, I'll be very ginger with them and keep that in mind. -------------------- taking too long to mod since '09
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 20, '09 From Winnipeg Currently Offline Reputation: 5 (100%) ![]() |
Yea the allen key hole on my endlinks were stripped after lowering my car as well. I was able to get them pretty tight, but there is still a lot of play in the endlink, so it makes a nasty clickin noise when i drive. But I don't want to tighten them anymore, or else they will get more stripped and I will ahve to cut them off.
-------------------- -Protection mode, For when your amp tries to blow its load. 1995 Toyota Celica GTS - Daily Driver 1999 Chevy Cavalier - Winter Beater 1994 Honda Civic CX Hatchback - Dead My Celica! |
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Apr 28, '09 From York pa Currently Offline Reputation: 3 (100%) ![]() |
i had to blow torch mine and then gave up and sawed them off
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 24, '07 From Oahu, Hawaii Currently Offline Reputation: 23 (100%) ![]() |
camber bolts arent needed at time of install, but you'll be needing them when you do alignment. if you have full race coils then you dont really need them cuz they usually come with PBM's
-------------------- I don't normally drive fast, but when I do its on a curvy section of this island
For a 1-2" drop, you won't really need the camber kit. It won't hurt anything to have it, but it's not necessary. As for the end links, just get some new ones anyway, even if you can reuse your old ones. Think about this: Your sway bar does not bolt directly up to anything except the end links. You've got 11 year old end links at the newest, if you're driving a '99 Celica. Your sway bar is a LOT thicker than those end links, so they've got some stress put on them over time. They are cheap. Might as well replace them while you are in there. It's like doing a motor swap. You wouldn't buy an old engine and put it in the car without buying a new water pump, timing belt, and gaskets. It's just something that you do when you do the work. Update the parts that you can.
Lo-Fi Version | Time is now: February 13th, 2025 - 6:54 PM |
