> Turn Signal Fuse Noise, Loud buzzing noise comes from fuse box
post Jul 29, 2010 - 12:48 AM
jussten
Joined Oct 31, '03
From Phoenix, Az
Hey, I've been having some issues with my turn signals.
Basically there is a loud Buzzing noise coming from the fuse box next to the steering wheel. When I pull the Turn signal Fuse the noise is gone but then the turn signals obviously don't function. Another thing is when I Use the turn signal the noise goes away until the turn signal is no longer in use.
Also, when Its especially Hot out (i live in az) the noise tends to go away or occurs less frequently, otherwise its a constant buzzing.
I'm going to take a look at it on friday and try to figure it out but I was hoping to get some ideas or suggestions. Anyone ever experience something like this?
post Jul 29, 2010 - 6:46 AM
the buzzing is the flasher relay. It's located right behind the interior fuse box. Check it to see if it's wet or just may need to be replaced.
post Jul 29, 2010 - 7:43 PM
jussten
Joined Oct 31, '03
From Phoenix, Az
QUOTE (Batman722 @ Jul 29, 2010 - 12:46 PM) *
Thanks, I'll try that first.
post Jul 31, 2010 - 3:07 PM
jussten
Joined Oct 31, '03
From Phoenix, Az
Thanks batman, that did the trick. I'm glad it was something so simple since my car had some previous electrical issues.
post Aug 1, 2010 - 12:47 AM
yuay !
Lo-Fi Version Time is now: November 23rd, 2024 - 7:18 AM
