Enthusiast Joined May 18, '10 From Beloeil Currently Offline Reputation: 0 (0%) ![]() |
Hi,
I just receive my IK20 and I'm new to the celica world. Should I need to gap them or do they came pre-gap from the factory? Thanks! This post has been edited by Lama: Jul 29, 2010 - 4:21 PM |
![]() Enthusiast ![]() ![]() ![]() Joined Feb 16, '06 From Maui, Hawaii Currently Offline Reputation: 6 (100%) ![]() |
No they are pre-gapped from factory so you shouldn't have to do anything with them.
Thanks !
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jul 12, '08 Currently Offline Reputation: 5 (100%) ![]() |
uh I sell parts all day long and one thing I can tell you is that even though plugs are supposed to be pre-gapped, a-lot of them aren't. In fact I had someone come in and buy some NGK double platinums the other day and he was paranoid enough to check the gaps right there at the counter. Sure enough 5 out of the 6 plugs were wildly out of gap. I attribute this to either factory mistake, shipping collisions, or just being dropped. That is why you should at least check the gaps before you put them into your car. Whats 5 seconds per plug after-all? And If they are out of range then adjust them using a regular gapper unless the plugs are fine-tip iridium, in which case gapping them with a feeler type gapper will ruin the plug. For iridiums you want to use the hook type gapper. So to everyone, ALWAYS check gaps!
![]() Moderator ![]() ![]() ![]() ![]() ![]() Joined Nov 5, '07 From New Zealand Currently Offline Reputation: 3 (100%) ![]() |
Found my thread from way back should be 0.8mm, which engine have you got just to be sure?
I have a 1994 GT. How much gap should they have?
Lo-Fi Version | Time is now: February 17th, 2025 - 7:08 AM |
