> Stubborn Crank pulley bolt 5sfe 98
post Jul 31, 2010 - 6:23 PM
chinamandrift
Joined Apr 7, '09
From cali
ok so i went to the store bought everything needed to do my water pump and timing belt over the weekend
98 celica 5sfe convertible
i got everything set up and started taking everything apart..
everything was cherry until ....i got to the crank pulley bolt ..
it will not move..ive tried 3 different impact guns
ive tried a special tool to hold the pulley in place with the bolt holes and the tool broke..
ive tried a single bolt and a pry bar to hold it in place and the bolt bent all to hell..
is there anything else i cant try to take this bolt out ...safely ?
id appreciate it if you guys have some ideas, i have 1 day left to work on it.. then have to travel back to school
post Jul 31, 2010 - 6:25 PM
Remy
Joined Jan 25, '06
From MN
I used the starter method but use it at your own risk I don't want to be reliable if you do it wrong Google it and you will know what I mean.
"To Protect And To Serve The Wealthy" -POLICE
post Jul 31, 2010 - 6:40 PM
chinamandrift
Joined Apr 7, '09
From cali
QUOTE (Remy @ Jul 31, 2010 - 7:25 PM) *
dont think this will work for me ...i already have taken the top section of the timing belt off ....and the engine is on TDC #1 comp ..has anyone tried heating the bolt up ? i heard that works ..
post Jul 31, 2010 - 7:29 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
you need a better impact and more importantly a better air compressor to drive it.
the starter method could work, how are you going to re-torque it?
post Jul 31, 2010 - 8:48 PM
Remy
Joined Jan 25, '06
From MN
QUOTE (chinamandrift @ Jul 31, 2010 - 6:40 PM) *
I loosened the crank bolt before I took anything off because I knew I was gonna run into this problem if I didn't do it first, you can always reconnect the timing belt and use the starter trick will save you time and headaches and worked with the first starter blip for me.
post Jul 31, 2010 - 10:36 PM
there is something called liquid wrench that freezes it and makes it easier..
post Jul 31, 2010 - 10:51 PM
Spider77
Joined Jan 17, '08
From JB MDL, NJ
Yeah, Granger makes something like that as well...freezing it causes the metal to contract, thus allowing an easier removal/installation (plus the Granger stuff also acts as a lube at the same time)
post Aug 1, 2010 - 10:48 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
ive put the car in gear and had a friend hold the breaks, if its a manual. you need to use 5th, though, and keep on the breaks HARD
post Aug 1, 2010 - 11:43 PM
JuMPiiN
Joined Nov 10, '09
From Louisiana
I tried liquid wrench on mine. It didn't work lol. I got tired of messing with it so I took it to the machine shop and he used some tool and got it off in like a few seconds. He did It for free but I paid him 20$ just for the help.
Lo-Fi Version Time is now: November 26th, 2024 - 9:40 PM
