> Celica GT4 Forge Engine Build, Upgrade
post Aug 2, 2010 - 5:41 PM
cloqwise
Joined Dec 10, '08
From Peterborough/Salisbury/Middlesbrough UK
Right this is going to be pic heavy but I have been building my car for a good while now and its pretty much finished. Done 2 threads on the TOC and gt4oc.net and i know most people on here are americans so i thought this would make a good source of info as you guys didn't get the st205 over there officially.
This is basically how the engine looked before i started stripping it, unfortunately the car club nazi's on my military base have taken up all the room in the garages I had to do this outside over late summer and through the winter. I'm sure people know about the UK weather so its not the best way to do this as i got frozen many a time.
Now as you can see the intercooler route isnt the best and basically the more i stripped the engine the more i learned and i would consider myself quite a knowledgable bloke on engines now cause i cannot stress how much you learn from doing this from rebuilding, general maintenance and modifying.
As you can by the big gap at the front i took the turbo off in a oner including the exhaust manifold, comes off really easy altogether was quite surprised. As you can see the exhaust valves are nicely scorched and gave me the idea of replacing all valves and doing a little more head work than planned. After i took the head off i took it to get skimmed and a bit of a clean up, this is what they found while skimming it, basically these are either det marks or where a piston ring exploded. Luckily as you can see on the picture all marks fit inside the gasket bracelet making the head still serviceable to use. Basically i have had 2 blocks before this so some parts have migrated over to this engine, back then i didnt do much on the car myself so whether i had cowboys working on the past engines who knows. My other two engines basically what happened was, crashed my car and cracked the block so rebuilt the car, finally discovered the block was knackered after elimnating everything else and got a new one in. After a few thousand miles i was having minor temperature problems with the new block so enough was enough, plus my last few gfs pissed me off enough to decide screw women for a while my car needs me more. You will see the problem i found later on but for now the head was skimmed by 0.005"
For uprating the head i decided on getting ferrea valves, titanium retainers, new collets, new buckets with 8mm shim, dual springs, HKS 264 camshafts and some vernier pulleys. 272 camshafts would have put the power band way up the rev range and would require extra machining on the valve train. The dual springs are proper nails, just so much stiffer.
New setup
Old setup
and where the engines at for the time being
Plus Suspension and driveshafts need disconnecting
Underneathe the car, prop shaft disconnected
Cross member needs to come out
Must apologise for the lack of action shots, this is my first strip and build, did it mostly on my own and was really focussed when i was set about the engine.
Right now for the fault with the engine, once i pulled the engine out the car i removed the pistons and this is what i found
A horizontal crack, quite rare as usually they are vertical and with a bit more blackening around it. Unfortunately this meant new block but someone off the gt4oc.net sourced one for me and she was in much better condition than my current block so was very happy.
After pulling the pistons, i did actually think to myself wouldn't it be great if they were some gucci racing pistons and this is what i found
Oh yes CP 86.5mm pistons, quids in boyos
Will start a second post cause this is going to be super long.
You Take Them Spoons Away He Cry Like A Baby, Mother F*ucking Spoon Love
- cloqwise   Celica GT4 Forge Engine Build   Aug 2, 2010 - 5:41 PM
- - cloqwise   Once I got all the gubbins out, i took the block t...   Aug 2, 2010 - 6:09 PM
- - cloqwise   Once a few parts turned up i started plodding on w...   Aug 2, 2010 - 6:26 PM
- - jordisonjr   Wow thats quite the work you've done ont his m...   Aug 2, 2010 - 6:56 PM
- - cloqwise   Really must apologise here, no action shots of put...   Aug 2, 2010 - 7:01 PM
- - cloqwise   One problem i had was my intercooler, bottom line,...   Aug 2, 2010 - 7:30 PM
- - cloqwise   SPEC SHEET HKS 264 CAMS INTAKE AND EXHAUST FERREA...   Aug 2, 2010 - 8:26 PM
- - enderswift   thats a pretty awesome celica there   Aug 2, 2010 - 11:47 PM
- - BriinumsBo   i guess copper spark plugs are better than platinu...   Aug 3, 2010 - 3:15 AM
- - cloqwise   im not really going for presentation so not too fu...   Aug 3, 2010 - 5:22 AM
- - stl95celica   move that front plate to the side so it doesnt blo...   Aug 3, 2010 - 10:46 AM
- - cloqwise   Ha already ahead of you mate, ordered a self adhes...   Aug 3, 2010 - 10:55 AM
- - HectortheRican   Very nice work. I just wish I didn't have to d...   Aug 3, 2010 - 11:19 AM
- - cloqwise   Beams is pretty good engine weren't they like ...   Aug 3, 2010 - 11:24 AM
- - HectortheRican   I don't care about big power. I just want a gr...   Aug 3, 2010 - 11:27 AM
- - cloqwise   Yeh i see what you mean, good handling, good power...   Aug 3, 2010 - 11:42 AM
- - HectortheRican   that's good stuff! The other day, the bolt...   Aug 3, 2010 - 11:46 AM
- - cloqwise   Very lucky the engine wasn't really torque rea...   Aug 3, 2010 - 11:58 AM
- - presure2   great build man, loving all the pics. only thing i...   Aug 3, 2010 - 4:37 PM
- - cloqwise   Really glad you pointed that out, such a daft mist...   Aug 3, 2010 - 4:57 PM
|- - presure2   QUOTE (cloqwise @ Aug 3, 2010 - 5:57...   Aug 3, 2010 - 5:23 PM
- - cloqwise   Cold air box has turned up, this should fit straig...   Aug 4, 2010 - 2:41 PM
- - cloqwise   Made some progress finally, just been making up th...   Aug 14, 2010 - 1:29 PM
- - cloqwise   Got my bov finally, I put the bov on but i'm g...   Sep 9, 2010 - 5:16 PM
- - JuMPiiN   I love your car bro, its beautiful and looks nice....   Sep 10, 2010 - 2:32 AM
- - cloqwise   I wasn't even looking for a gt4 originally let...   Sep 10, 2010 - 9:09 AM
- - Punch   i love the build ..... uk guys have all the best ...   Sep 11, 2010 - 10:41 PM
- - cloqwise   To be honest mate, a lot of my stuff mainly the st...   Sep 18, 2010 - 6:35 PM
|- - TRDGT4   QUOTE (cloqwise @ Sep 18, 2010 - 6:3...   Sep 25, 2010 - 5:18 PM
- - Punch   did you dyno the car yet???   Sep 24, 2010 - 7:11 PM
- - cloqwise   Not yet mate, i'm still running her in, only d...   Sep 25, 2010 - 4:57 PM
- - cloqwise   What are after market part prices like in aus and ...   Sep 25, 2010 - 5:30 PM
- - TRDGT4   Havn't really brought parts from Aus but I kno...   Sep 25, 2010 - 6:31 PM
- - cloqwise   Right been a bit busy on my bike but because of th...   Oct 23, 2010 - 6:35 PM
- - cloqwise   This is just some videos of her, she's running...   Nov 27, 2010 - 6:17 PM
- - cloqwise   just bought this sexual bit of kit http://cgi.ebay...   Nov 30, 2010 - 6:29 PM
- - enderswift   fantastic. like always   Dec 1, 2010 - 1:02 AM
- - cloqwise   Right been fixing my mates golf cause he crashed i...   Dec 18, 2010 - 6:49 PM
- - cloqwise   I will be putting these rims on my car in 18x8: ht...   Dec 18, 2010 - 6:58 PM
- - PolliS_5S-FE   This is a pretty mad build man!! Yeah, com...   Dec 27, 2010 - 8:45 PM
- - cloqwise   Oil return pipe, managed to get a male -10 turbo f...   Jan 11, 2011 - 6:12 PM
- - cloqwise   Right got some pictures of my oil return and some ...   Jan 22, 2011 - 2:53 PM
- - alltracst185   QUOTE (cloqwise @ Dec 18, 2010 - 6:5...   Jan 22, 2011 - 9:41 PM
- - cloqwise   Sorry wheels already been sold. Well, to put it s...   Jan 28, 2011 - 8:54 PM
- - bsamps4   is one of your pistons backwards?   Jan 29, 2011 - 6:15 PM
- - cloqwise   What do you mean?   Jan 29, 2011 - 9:35 PM
- - bsamps4   It actually appears that three of the pistons are ...   Jan 30, 2011 - 10:17 AM
- - bsamps4   You can see the reliefs here in this picture   Jan 30, 2011 - 10:34 AM
- - presure2   its not an interference motor, but yea good catch...   Jan 30, 2011 - 10:59 AM
- - cloqwise   i've like done 4 build threads and no one has ...   Jan 30, 2011 - 11:13 AM
- - bsamps4   I hope it isn't too much trouble for you to ge...   Jan 30, 2011 - 12:13 PM
- - cloqwise   I can do it all in situ and it gives me an excuse ...   Jan 30, 2011 - 12:59 PM
- - bsamps4   Post lots of pics!   Jan 30, 2011 - 1:02 PM
- - cloqwise   I will mate.   Jan 30, 2011 - 2:16 PM
- - bsamps4   I'd recommend using the ATS racing gasket. It...   Jan 30, 2011 - 9:45 PM
- - Kingsoup   Great Build thread! I didn't even know you...   Feb 8, 2011 - 11:31 AM
- - cloqwise   Had it back together for a while now, sorry i didn...   Mar 28, 2011 - 2:40 PM
- - bsamps4   Bad ass man. Glad it went back together nicely. Ch...   Mar 28, 2011 - 3:39 PM
Lo-Fi Version Time is now: January 11th, 2026 - 7:17 PM
