air intake? |
air intake? |
Aug 3, 2010 - 2:23 PM |
Enthusiast Joined Jul 28, '10 From Wrentham, MA Currently Offline Reputation: 0 (0%) |
well i just installed my air intake, short ram? like im said first project car, and installed it myself... hopin i did everything right... had a left over hose and a nipple comin off the intake piping tht i had no idea wat to attatch because there was nothing i pulled from the stock intake that resembled it in use....
any input would be awesome, dont want to kill my celica after a month look good? |
Aug 4, 2010 - 9:50 PM |
Enthusiast Joined Jul 3, '09 From UT Currently Offline Reputation: 14 (100%) |
its an unused nipple. I just wrapped mine in enough good electrical tape to seal it. I didnt have the stuff to weld aluminum.
Aug 4, 2010 - 10:07 PM |
the left over hose attaches to the nipple that you didn't use. I just installed my weapon-r today, but i had to extend the extra hose
also, did you drill a hole and put the air sensor in? you will possibly need that installed to pass inspection This post has been edited by mkernz22: Aug 4, 2010 - 10:11 PM |
Aug 4, 2010 - 10:35 PM |
the left over hose attaches to the nipple that you didn't use. I just installed my weapon-r today, but i had to extend the extra hose also, did you drill a hole and put the air sensor in? you will possibly need that installed to pass inspection air sensors in, install kit came w/ a hole and gromet in it already, its on the back side, had to relocate the wiring to reach and fit the pipe.... deffinatly upgrading tht air intake at some point but thought why not blow the $25 now for something funesk |
Aug 4, 2010 - 10:42 PM |
Enthusiast Joined Mar 16, '09 From New York Currently Offline Reputation: 23 (100%) |
good job should a got a CAI IMO but still looks good. And the nipple thing, is on mine as well, but mine also came with a little rubber cap, i just put on it. You should also drill out the hole for your intake temp sensor.
I had a pic of my intake sensor, but i cant find it. You can see in this pic, the nipple on mine, and the little black cover i put in it, I assume that electrical tape will work just the same GL -------------------- |
Aug 4, 2010 - 11:09 PM |
Oh god, its like Superman took a dump in your engine bay.....
Aug 4, 2010 - 11:14 PM |
Enthusiast Joined Apr 17, '10 From U.P. michigan GO STATE Currently Offline Reputation: 3 (100%) |
you could also do what i did to mine and add hose to the end of that filter, looks like a spectra filter like mine, anyways take and run it through the old air box hole and down into the front fender, it will pick up some more cold air.
Celica: The name is derived from the Spanish word for "heavenly" or "celestial". Back-2-Back July COTM 15&16 |
Aug 4, 2010 - 11:16 PM |
Enthusiast Joined Jan 16, '07 From covington, KY Currently Offline Reputation: 9 (77%) |
good job should a got a CAI IMO but still looks good. And the nipple thing, is on mine as well, but mine also came with a little rubber cap, i just put on it. You should also drill out the hole for your intake temp sensor. I had a pic of my intake sensor, but i cant find it. You can see in this pic, the nipple on mine, and the little black cover i put in it, I assume that electrical tape will work just the same GL Oh god, its like Superman took a dump in your engine bay..... This post has been edited by hatchy_gt-s: Aug 4, 2010 - 11:17 PM |
Aug 4, 2010 - 11:33 PM |
Enthusiast Joined Mar 26, '09 From Minnesota Currently Offline Reputation: 5 (100%) |
-------------------- "God created turbo lag to give V8's a chance"
Aug 5, 2010 - 1:37 AM |
Enthusiast Joined Dec 26, '09 From Albuquerque, NM Currently Offline Reputation: 19 (100%) |
Go to Pep Boys or Auto Zone and they have little rubber caps that you can cover that nipple with. Why not spend an extra 2-3 bucks so you're not ghetto rigged?
June '12 COTM '95 AT200 |
Lo-Fi Version | Time is now: January 11th, 2025 - 5:12 PM |
