> Is it possible to rebuild a power antenna?
post Aug 5, 2010 - 6:49 PM
RavenAegis45
Joined Jun 25, '08
From CA
well I pulled my power antenna out today in preperations to paint my car, having some spare time i decided to open the bugger up and not so surprisingly I found that pieces of white plastic mast guides scattered about the gooey inards, my question is it possible to just replace the guides or impossible all together?
post Aug 5, 2010 - 7:36 PM
pyeatts
Joined Jun 9, '09
From Saint Louis
I think what you're talking about is the teeth on the gator rib coming out of the mast. It's part of the mast and you can replace the mast. Part 86337-2B200 Also, before you put the cover back on coat the inside with white lithium greese. Make the new mast rib last for good!
post Aug 5, 2010 - 7:39 PM
RavenAegis45
Joined Jun 25, '08
From CA
QUOTE (pyeatts @ Aug 5, 2010 - 7:36 PM) *
Ok thanks for the tip and yeah its the long white coily thing connected to the mast, its all in pieces, and thanks for clarifying the lithium greese also I didn't know what kind it was when i opened it up
post Aug 6, 2010 - 1:42 PM
you have to open it up to remove all the pieces. otherwise kaput.
Lo-Fi Version Time is now: January 10th, 2025 - 9:36 AM
