> How to flush cooling system?, Over heating after Godspeed radiator install
post Aug 6, 2010 - 9:59 AM
NWCelica
Joined Oct 16, '07
From Seattle
Just installed a Godspeed radiator and forgot to flush it before hand. Car is overheating and don't want to ruin a new engine I need to know how to flush the system to remove any junk that mite have been left inside from mfg. Nice radiator but the oem fans don't fit and the onus that came with it are junk.
Thanks
post Aug 9, 2010 - 7:58 PM
mkernz22
Joined May 10, '10
From MA
I just flushed my system out with water, but you can buy flush kits at auto zone or advance auto. Also, you do need the fans on your radiator! that's what helps it from over heating as well cause the fans help cool it. Also, did you take the temp sensor out of your old one and put it in the new one? if you didn't your car will over heat cause it doesn't know the temp of the fluid.
Lo-Fi Version Time is now: November 30th, 2024 - 5:30 AM
