> manual transmission is stuck in reverse.
post Aug 7, 2010 - 9:57 AM
Ethnykceli
Joined Jan 14, '05
From Miramar, Florida
im haveing a problem with my transmission, on day i was leaving from my house to go over to a friends house. so i shift into reverse to pull out the drive way. when i try to shift into first the shifter wont move it just stay in reverse. i can drive in reverse but no way to take it out. i check the linkage cables but there are working perfectly. i kinda stuck on what to do or whats wrong with it.
post Aug 7, 2010 - 2:59 PM
did you try moving the shifter with the car off?
have someone press the clutch pedal, and verify the slave cylinder clutch rod is moving.
post Aug 12, 2010 - 1:27 PM
Ethnykceli
Joined Jan 14, '05
i tried to move the shifter with the car off and it did not move at all, also i verified that the slave cylinder clutch rod is moving.
Lo-Fi Version Time is now: February 18th, 2025 - 1:11 PM
