Install Dash Pods |
Install Dash Pods |
Aug 9, 2010 - 10:39 AM |
Enthusiast Joined Mar 11, '09 From Baltimore, Maryland Currently Offline Reputation: 1 (100%) |
Hi all!
I got my single pod and I'm about to get a triple dash pod. I wanted to know from others who have them how did you mount the pods? What did you use to adhere them to the dash? Velcro or some kind of metal bracket? I assume it should be removable in case you change the gauges and or need to troubleshoot the wiring but strong enough that they don't bounce around or pop off when you hit a bump. Actually I open this up to anyone with ideas and creative thoughts on this. Thanks everyone, speed-ccnp |
Aug 9, 2010 - 10:49 AM |
Enthusiast Joined Apr 24, '07 From CA Currently Offline Reputation: 1 (100%) |
Maybe some double sided tape could do the job
-------------------- QUOTE what hes saying is if you put blue lights in you car youll lose hp. |
Aug 9, 2010 - 11:07 AM |
Enthusiast Joined Apr 28, '09 From York pa Currently Offline Reputation: 3 (100%) |
i was thinking maybe some velcro wont damage any just leave sticky residue if removed which should come right off
Aug 9, 2010 - 9:12 PM |
Check any local hardware...like Home Depot, or lowes...
They have industrial strength velco...this stuff is serious business. Like shark teeth aligning some how to create the ultimate bond. Takes quite a bit of effort to remove the item...sometimes the glue is weaker then the velcro...its in small 2-5 inch strips. Works great, use it quite a bit at work to hold heavy items to fixed locations =P |
Aug 10, 2010 - 9:00 PM |
cool, Velcro it is!!
Thanks for the ideas. |
Lo-Fi Version | Time is now: November 29th, 2024 - 7:50 PM |
