Enthusiast ![]() Joined Dec 8, '09 Currently Offline Reputation: 0 (0%) ![]() |
Both of my reverse lights are out, I couldn't find a fuse that was marked as reverse lights so I checked every fuse and none of them we're broken, so I attempted to change a bulb, still nothing! Any idea what could be the problem?
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 16, '09 From New York Currently Offline Reputation: 23 (100%) ![]() |
there was literally just a thread on this? but i cant find it now, if worst comes to worst runs wires to a switch and have a switch for them
Enthusiast ![]() Joined Jun 9, '09 From Saint Louis Currently Offline Reputation: 0 (0%) ![]() |
It's probably your reverse switch under the shifter boot. If you need a diagram let me know, but it's easy to find. Pull the boot bezel and move the shifter to reverse, you'll get it!
alright thanks i'll look into it
Enthusiast Joined Aug 13, '10 From Australia Currently Offline Reputation: 0 (0%) ![]() |
iv got a 1994 st204 automatic my reverse lights are not working, i checked globes, fuses, checked wiring back half way inside the car.
iv had a look at the reverse switch on the gearbox. but im unsure which plug is the reverse switch. i believe its the 2 wire plug next to the linkages. i have tried bridging the wires on the two pin plug (next to linkages) and reverse lights still dont work. i may have the wrong plug. also does anyone have a electrical wiring diagram for this model. thanks This post has been edited by jinks_one: Aug 13, 2010 - 3:21 AM |
Lo-Fi Version | Time is now: February 17th, 2025 - 12:40 PM |
