> Need To Degrease My Engine
post Aug 12, 2010 - 3:51 PM
MauiBuilt
Joined Nov 22, '06
From Maui, HAWAII
Aloha! smile.gif I need to degrease my engine soon. I brought a can of Johnsen engine degreaser. My engine is a 5S-FE, what needs to be covered from water protection? Mahalo! wink.gif
post Aug 12, 2010 - 5:34 PM
JuMPiiN
Joined Nov 10, '09
From Louisiana
Cover you diztributor cap for sure, and the more important wires, spray on the degreaser and let it sit for like 10-20 minutes. then spray it off or pressure wash it. I pressure washed mine. I did it like 3 times.
post Aug 12, 2010 - 7:12 PM
Agent21
Joined Sep 12, '05
From Who says you can't circle race a celica?
Have the engine running while you do this that way you won't water log it.
94 GT Liftback
86 GTS Coupe (Racecar) #99 Crew Chief
post Aug 18, 2010 - 11:11 AM
netrata
Joined Feb 16, '06
From Maui, Hawaii
Like the other guys said, make sure to cover all the ignition related wires and components and also it wouldn't hurt to cover the alternator if you decide to keep the engine off. I'd avoid using a pressure washer on the engine itself since it will force water through the valve gaskets and so forth (seen it happen to a friends car). It would be good to use those steam cleaners after degreasing as it helps break up all that debris on the head and block, if not then regular water and toothbrush will be just as good. BTW I use simple green as a degreaser cause it smells better thumbsup.gif
This post has been edited by netrata: Aug 18, 2010 - 11:20 AM
Lo-Fi Version Time is now: February 17th, 2025 - 8:37 AM
