> Slight crunch on the coupe., Will probably need parts in the near future.
post Aug 15, 2010 - 3:29 PM
lilgreenyoda
Joined Jan 22, '07
From Loveland
Words do not explain. Pictures do. Here is the pic.
So pretty soon it looks like I'm gonna be doing some work here. I'm thinkin this is my excuse to paint 'er a color that's... well... cool. Cause I'll be sanding that side (obviously) and at least 80% of the rest of it to fix other things. Sooo this'll be fun. Anyway, I'll probably be on here scouring for parts due to this. But but my parts search won't be limited to what you see.
post Aug 15, 2010 - 3:41 PM
Spider77
Joined Jan 17, '08
From JB MDL, NJ
Ouch
post Aug 15, 2010 - 6:41 PM
HectortheRican
Joined Dec 26, '09
From Albuquerque, NM
Tough luck man kindasad.gif I was there a month ago, keep your head up
June '12 COTM
'95 AT200
post Aug 15, 2010 - 7:04 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
that looks like it'll mostly pop out. and in a pretty easy place to reach from the back.. carefully beat it out and it sould take minimal bondo to make look good. the ONLY thing that would worry me is the factory crease on the loswer part of the body... thats a bicth to rebuld w/ bondo
still REALLY sucks kindasad.gif sorry bro. i've been there more than once.. actually all FOUR of my celis had major dentage
post Aug 17, 2010 - 10:48 PM
lilgreenyoda
Joined Jan 22, '07
From Loveland
Yeah, I figure most of it will pop out. I'll just make sure and take my time with the factory crease. I'm hoping I don't have to cut and hang a new panel piece (And weld it in and pray to the almighty that it doesn't rust). But like I said. Perfect excuse to paint 'er a nice color. smile.gif
post Aug 17, 2010 - 11:40 PM
enderswift
Joined Jul 12, '08
ow. right there with ya man, that must get on your nerves every time you look at it. But hey it coulda been worse, imagine if they crunched in your wheel instead!
As for how to go about fixing things, you don't have cut and weld in a new panel. Don't let anyone tell you otherwise. Not only is it labor intensive, but you also run the risk of having it rust. Not to mention welding itself distorts the metals a bit. So do the easiest thing and just tack on some prongs to pull that dent out.
This post has been edited by enderswift: Aug 17, 2010 - 11:43 PM
post Aug 20, 2010 - 1:15 AM
lilgreenyoda
Joined Jan 22, '07
From Loveland
Right, exactly. I'm going to try and avoid doing surgery on it if at all possible. And up close it looks like I really won't need to. Plan is to strip the paint down, pop it out where I can, make holes ONLY where I need to. Mix up a little bondo, primer, and go. I just hope the insurance company (the other guys) splits out enough cash to get the gear I need to do it. I should be finding out about that tomorrow.
Lo-Fi Version Time is now: February 23rd, 2025 - 7:16 PM
