> Diamond Racing Steel Wheels, 6gc?
post Aug 16, 2010 - 8:25 PM
alakai
Joined Jan 2, '09
From California
Hi. I'm going to be purchasing some of these steele wheels soon. Basically re-barreled steelies. I was wondering if anyone here on 6gc had a set yet and any pics on a 6gc.
post Aug 16, 2010 - 8:32 PM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
No, no one with a 6gc has done it yet. Yes, you should do it. No I can't tell you which offset to get, you should look in Harold's flush wheel fitment thread for width and offset information.
And now I have answered all of your following questions before you could ask them. tongue.gif
**** Photobucket
post Aug 16, 2010 - 8:36 PM
alakai
Joined Jan 2, '09
From California
Too bad I did my research on the fitment smile.gif. One step ahead of you buddy. They don't do offset, they do backspace which is their version of offset and I have a full conversion chart if anyone would like. I will be posting picks once I have them on. And yes I will he hellaflush buooooy! I just wanted to see a pic before I bought them but I guess I will be providing the pic smile.gif
post Aug 16, 2010 - 8:59 PM
95CelicaST
Joined Feb 5, '05
It was always something I thought about doing, because the celica is slow, so lightweight weeks aren't going to make or break you... So why not roll with really heavy steelies.
**** Photobucket
post Aug 17, 2010 - 1:43 PM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
-5 on front and -15 rear. you'll need 3 sets of camber bolts 2 sets for the rear and 1 for the front. then you'll need pillowball mounts up front too
post Aug 17, 2010 - 4:45 PM
alakai
Joined Jan 2, '09
From California
808 what width of wheels would your calculations be based on? And 3 camber bolts? And pillowbars? Ill have to do some more resarch to see alll that I need to run my setup. Which will be within the next month or two
post Aug 18, 2010 - 8:51 AM
Culpable04
Joined Apr 17, '06
From New Jersey
it is not recommeded to use camber bolts and camber plates at the same time on a single strut assambly, and 2 sets of camber bolts on one single strut assambly is not a good idea either, but that may be a new trend on the hellaflush world.
post Aug 18, 2010 - 8:55 AM
alakai
Joined Jan 2, '09
From California
I was just looking to get goils with adjustable camber. Which would you guys recomend?
post Aug 18, 2010 - 10:44 AM
95CelicaST
Joined Feb 5, '05
Just buy a cheap set of coilovers like megan or ksport and utilize the camber plates. The rears probably aren't camber adjustable, and if that is the case then a camber bolt can be used. 1 per side, not two.
**** Photobucket
post Aug 18, 2010 - 10:53 AM
Culpable04
Joined Apr 17, '06
From New Jersey
Stay away from Ksports
Coilovers that come with camber plates are design to work only with the coilover system, I tried using the Ksport camber plates on my tein coilovers and no luck.
post Aug 18, 2010 - 11:10 AM
EKAn
Joined Apr 24, '07
From CA
how much are the wheels going to cost?
what hes saying is if you put blue lights in you car youll lose hp.
post Aug 18, 2010 - 12:35 PM
95CelicaST
Joined Feb 5, '05
I imagine they're around $85/wheel
**** Photobucket
post Aug 18, 2010 - 1:57 PM
alakai
Joined Jan 2, '09
From California
The wheels vary in price depending on your choice of wheel and size and/or if you want a custom wheel. They are fairly cheap though you can easily cash out 280 for a set. As far as coilovers are concerned what is cheap? Cuz all I can find is 800 and up. That really is not cheap in my opinion.
post Aug 18, 2010 - 2:16 PM
95CelicaST
Joined Feb 5, '05
800 - 1000 is cheap.
**** Photobucket
post Aug 18, 2010 - 2:56 PM
stl95celica
Joined Oct 22, '08
From St.Louis
My plan is to get these wheels but your going to need a serious drop. i was going to get the 15x8
-frank
Lo-Fi Version Time is now: January 5th, 2025 - 9:43 PM
