Enthusiast ![]() Joined Aug 11, '10 From Alberta Currently Offline Reputation: 0 (0%) ![]() |
Picked up my first 1995 Celica GT today and after driving it for awhile it really seems to fall on it's face after about 5000RPM.........any ideas why it's doing that? Fuel pump? Bad intake? Injectors? First thing tomorrow I'm removing the intake and cleaning the TB and the intake filter and then a full tank of 93 octane. I'll probably check the spark plugs/gaps while I'm in there, anyone know what the stock gap should be? Only mods it has are a DIY intake and a full catback exhaust.
This post has been edited by RockyMountainCelica: Aug 17, 2010 - 1:20 AM -------------------- 2009 Chevy Cobalt SS Turbo "Torque Monkey" SOLD
1993 Honda Civic Si "Mean Green Cornering Machine" Track Whore 1995 Toyota Celica GT "Baby Supra" Daily Driver |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 16, '09 From New York Currently Offline Reputation: 23 (100%) ![]() |
well i only have an ST, but from what im told.. the GT isnt too much different. My engine runs perfect, nothing at all wrong everything new, but i dont have any power past 5k, past 4k really for that matter. I just dont think it (7a at least) is meant for that kind of driving. Maybe with all the things you said, and a header it can get a little more power? but i dont imagine much
3s FTW ![]() -------------------- |
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Mar 8, '08 From Orlando, Florida Currently Offline Reputation: 14 (100%) ![]() |
the 5sfe is useless after about 5200 rpm. check the dyno threads stickied at the top to see for yourself. it can be corrected with a set of reground cams. i've noticed a little difference in acceleration after putting in the ebay header, but no documentation for that.
![]() the only difference premium fuel will make is in your wallet, but thats your decision... -------------------- ◊◊◊ My F/S Thread! ◊◊◊
the 5sfe is useless after about 5200 rpm. check the dyno threads stickied at the top to see for yourself. it can be corrected with a set of reground cams. i've noticed a little difference in acceleration after putting in the ebay header, but no documentation for that. ![]() the only difference premium fuel will make is in your wallet, but thats your decision... I found in my civic that i got better MPG and the car ran smoother on premium, would the same not be true with my Celica? It does already have 285,000km(177,090miles) and that alone I figure would make it worth while to run premium. -------------------- 2009 Chevy Cobalt SS Turbo "Torque Monkey" SOLD
if you are in the rocky mountain area as your name implies, you all get fuel with a lower AKI because of your elevation, and it has been shown to provide the same performance as the higher octane we receive at lower altitude, however i suppose it is plausible that you notice an effect, based on your elevation.
edit: anyway, at 5000+ rpm, gas mileage goes out the door, ![]() This post has been edited by samir0189: Aug 17, 2010 - 1:46 AM -------------------- ◊◊◊ My F/S Thread! ◊◊◊
if you are in the rocky mountain area as your name implies, you all get fuel with a lower AKI because of your elevation, and it has been shown to provide the same performance as the higher octane we receive at lower altitude, however i suppose it is plausible that you notice an effect, based on your elevation. edit: anyway, at 5000+ rpm, gas mileage goes out the door, ![]() fair enough, i appreciate any and all input as this is a new car to me. This post has been edited by RockyMountainCelica: Aug 17, 2010 - 2:03 AM -------------------- 2009 Chevy Cobalt SS Turbo "Torque Monkey" SOLD
![]() Enthusiast ![]() ![]() Joined Oct 22, '08 From St.Louis Currently Offline Reputation: 1 (67%) ![]() |
My GT did the same. But when i put my ebay header an short ram intake on it goes to 6k in the power band
-------------------- -frank
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Oct 20, '08 From Seattle, WA Currently Offline Reputation: 5 (100%) ![]() |
The 5sfe's max torque is at 5400 RPMs
-------------------- 2006 BMW 330i - 6 Speed - Dinan Stage 1
2014 Toyota Rav4 XLE |
The 5sfe's max torque is at 5400 RPMs yea i'm still learning the shift points, i really got shift quickly out of 1st but i keep forgetting and riding it up for nothing, lol I'm used redlining my civic. -------------------- 2009 Chevy Cobalt SS Turbo "Torque Monkey" SOLD
![]() Moderator ![]() ![]() ![]() ![]() ![]() Joined Jun 29, '08 From Denver Currently Online Reputation: 59 (100%) ![]() |
Running a higher octane fuel won't do anything for power. It just keeps the fuel from detonating too soon, which keeps the engine from knocking. It's useless unless your engine is high compression or boosted. A stock 5S will do fine on regular fuel and save you ~$5 per fill-up. The 5S is definitely not a performance motor. Just an economy engine that happens to take to boost well. (Hint hint.)
Lo-Fi Version | Time is now: February 17th, 2025 - 7:25 AM |
