FS...GEN3 ST205 SWAP, WITH PLUG AND PLAY ENGINE HARNESS, NO WIRING NEEDED |
Sep 3, 2010 - 11:36 AM |
Enthusiast Joined Sep 22, '08 From Bergenfield Currently Offline Reputation: 5 (78%) |
Were are the pic's at bro!!!! There coming soon Axel. I recently purchased myself a 1993 Celica Alltrac that me and my brother are putting together as we speak. I purchased the car with the orignal engine completly dismantled and only hanging from one out of the 4 engine/tranny mounts. (I have pics, I will need to post them up). So we are in the process of dropping in one of my GEN3 3sgtes that I offer for sale here to the community. I will post pics of the engine, wiring harness, the head with the valve cover off, the upgraded performance W2A IC system, and the performance 3.5" intake that all comes standard with my engine sets. With the new performance upgrades, and the plug and play harness I will show how easy it is to drop one of my engine sets in, and the lack of need to source parts that come missing with other engine sets. I wont be using anything from my shop other then a 20G turbo kit that I built myself. This will show that my engine sets are truly the most complete, clean, plug and play 3sgte engine sets available today, as I am starting with a car that literally has no motor to speak of. Again, I will only be using parts from THE SAME engine sets I offer to the community, and nothing else (other then an upgraded 20G turbo, GSC GEN3 S1 performance cam shafts, and an act 6 puck clutch....these are all purely upgrades and are not/were NOT needed) Stand by for pictures... This post has been edited by _Jim_: Sep 3, 2010 - 11:39 AM --------------------
Sep 3, 2010 - 1:11 PM |
Enthusiast Joined Nov 10, '09 From Louisiana Currently Offline Reputation: 5 (100%) |
Your sets come with a the tune up parts, like oil pump,water pump, all that stuff as well ? |
Sep 3, 2010 - 11:12 PM |
Enthusiast Joined Mar 7, '10 From Ft. Lauderdale Currently Offline Reputation: 9 (100%) |
all depending on how my job works out, if you would still be selling these next summer, i may be interested in buying one.
Feb 10, 2011 - 10:11 PM |
Enthusiast Joined Dec 29, '05 From So-Cal Currently Offline Reputation: 12 (100%) |
update me jim, put me on the list.
This post has been edited by chacha: Feb 10, 2011 - 10:12 PM |
Feb 11, 2011 - 9:19 AM |
You have a PM chacha
I thought I would list this now for anyone who is looking to do a swap in the spring. The GEN3 that is currently in my alltrac will be coming out in the next 2-3 months for the built motor I have been slowly gathering parts for. I only put this GEN3 in to get the car running for the time being, and to work out any bugs on the car while still on a stock GEN3 ECU before upgrading to the build and standlone. What you see is what you get. It is a COMPLETE GEN3 swap (obviously, because it is running in my alltrac) just like all my other motor sets, but this one is better. You will be getting a COMPLETE GEN3 3SGTE motor set that has had all the gaskets checked and replaced as needed, new high performance ACT 6 puck clutch installed, Upgraded adjustable cam gears, Motor cleaned, prepped,.... Intake manifold, Valve cover and heat shield painted. Also...I upgraded the from the CT20B to a TD06 turbo kit before I ever installed the engine into the car. This engine and turbo kit upgrade will max out your factory fuel system under 20psi. So instead of buying a stock GEN3 where you need to replace the gaskets, do a timing job, and upgrade the clutch, and get a downpipe, etc...and still be on the stock CT20b making 300whp at 18psi. You can choose to run this setup and LITERALLY just drop it in when you recieve. Me and Manny have done all the work for you. And you will be making 360+whp at 18psi with this turbo kit, as apposed to 300whp with the stock GEN3. Right now I have a FMIC on my alltrac, but if you buy this setup...I will reinstall the factory W2A unit with upgraded heat exchanger and upgraded pump. Price for a standard GEN3 with upgraded Heat exchanger and upgraded pump, and plug and play harness 2800 shipped to your door. Price for the GEN3 setup in my alltrac with upgraded heat exchanger, upgraded pump, and plug and play harness....3500 shipped to your door. --------------------
Feb 11, 2011 - 10:38 AM |
Enthusiast Joined Nov 29, '07 From Colorado Currently Offline Reputation: 4 (100%) |
I'd be interested in the full shebang, if you're interested. AWD+3S-GTE. Send me a PM!
-------------------- 2019 M2, 2005 S2000, 1997 4Runne
Feb 11, 2011 - 2:13 PM |
Enthusiast Joined Aug 12, '07 From Lancaster, Pa Currently Offline Reputation: 35 (100%) |
wow.
Feb 11, 2011 - 2:19 PM |
def, in for the alltrac one....pm you jim
Feb 11, 2011 - 3:00 PM |
Enthusiast Joined Dec 2, '09 From Chino Hills, CA Currently Offline Reputation: 8 (100%) |
if only i had the money
Feb 11, 2011 - 8:57 PM |
Enthusiast Joined Mar 13, '10 From New Iberia Currently Offline Reputation: 0 (0%) |
Ill buy one if you still have any left when april comes.($2800 deal)
Feb 14, 2011 - 7:15 AM |
Enthusiast Joined Feb 2, '11 From minnesota Currently Offline Reputation: 0 (0%) |
cool
This post has been edited by gt4celica90: Feb 14, 2011 - 7:18 AM |
Feb 16, 2011 - 7:10 PM |
xcvI have a lot of questions about the motor in the alltrac.
Yes it is a GEN3 in my alltrac. Yes it will come with a plug and play engine harness for your 6GC Yes, it is a drop in ready setup...IT IS RUNNING in my alltrac Here is the build thread with all the info on the motor http://www.6gc.net/forums/index.php?showtopic=76683 --------------------
Feb 21, 2011 - 11:48 AM |
Enthusiast Joined Jan 10, '11 From Trail BC Currently Offline Reputation: 1 (100%) |
I have 3 ST205 GEN3 3SGTE's in stock and up for sale. These engines will come with everything needed to drop into your 6th Gen Celica. They come complete with an uncut wiring harness, complete Water to Air intercooler system, map sensor, igniter, coil, etc. I am also offering a free wiring harness conversion that will make installing this engine into your 6GC plug and play. There will be no wiring needed on your end. Just remove your engine, install this 3sgte with professionally converted harness, and start the car. No more tracing wiring gremlins, or have a check engine light for code 54, all these have been taken care of!!! I am also going to be throwing in an upgraded Water to Air intercooler system. Efficient enough to support 500+hp. It will come with a LARGE 24x12 heat exchanger, upgraded Bosch pump with wiring adapter, pump mounting kit, and all necessary fittings. You will also be receiving a performance 3.5" after market intake at no additional cost. This is truly the most complete, plug and play 3sgte engine set on the market today....and as always, comes with free shipping and 90 day warranty on block and head to be free of defect. All engines are compression checked before being shipped to assure a quality, healthy motor. Jim, really need a map sensor for st205..can you help me out? Price for the complete GEN3 ST205 3sgte with plug and play harness conversion, 3.5" intake, upgraded Water to Air Intercooler system efficient enough to withstand 500hp TOTAL 2800.00 WITH FREE SHIPPING anywhere in the continental US Total with everything listed above minus the Water to Air intercooler system: (Perfect for those looking to run a Front Mount Intercooler) 2500.00 with free shipping |
Feb 23, 2011 - 7:53 PM |
Enthusiast Joined Mar 16, '09 From New York Currently Offline Reputation: 23 (100%) |
JIM, your inbox is full! Please message me, i want to buy the alltrack engine!
Or email mgnt232@hotmail.com thanks alot, hope its still available -------------------- |
Feb 25, 2011 - 3:26 AM |
Enthusiast Joined Oct 16, '10 From Vancouver Currently Offline Reputation: 0 (0%) |
just a quick question, would this fit where a 7A-FE engine is???
thanks |
Feb 26, 2011 - 5:02 PM |
Enthusiast Joined Jul 27, '06 From Soda Currently Offline Reputation: 9 (91%) |
you need GT engine mounts. -------------------- |
Feb 26, 2011 - 6:40 PM |
Mar 27, 2011 - 3:06 PM |
Enthusiast Joined Dec 22, '05 From Brockton, MA Currently Offline Reputation: 0 (0%) |
Any of these still for sale?
Mar 27, 2011 - 11:49 PM |
Any of these still for sale? Hey frank, Jim will set you up with whatever you need. My cousin and I both got our clips thru him. -------------------- Former Team 5SFTE pro member ;)
13.6@108MPH, 5SFTE Powered |
Mar 28, 2011 - 3:46 PM |
Thanks Manny! I've been shopping for a decent 6th gen shell, and I'd like to put a 3rd gen in it. Jim's deal seams too good to pass up.
Looking forward to CSP! P.S. If you know of any good shells, let me know. I'm planning a trip to jersey just to pick one up. |
Lo-Fi Version | Time is now: December 3rd, 2024 - 4:19 AM |
