e153 Parts list for 98 GT vert |
Aug 18, 2010 - 5:57 PM |
Enthusiast Joined Apr 7, '09 From cali Currently Offline Reputation: 0 (0%) |
ok so im going to rebuild my manual transmission
and i run into this problem where i have trouble finding transmission information everything is not listed clearly. i have a 98 celica GT 5sfe manual convertible the info i need: -what Transmission code do i currently have? - what are my alternate transmission code options from other cars ? -in what car do i find these other transmissions? -i need transmission ratios..i see a page with ratios listed but does not tell me transmission code -im looking to replacing my final ratio/ or 5th gear to a longer gear ratio. My car does a hair less then 4k RPM at cruise 70mph . Do all the parts in these transmission interchange? - are there alternative gears i can use from other transmissions? -Are engine/transmission mounts different in a convertible vs a hardtop id like to build a manual transmission list and info on interchangeable parts since i am having a hard time looking for the info i need This post has been edited by chinamandrift: Aug 18, 2010 - 7:51 PM |
Aug 18, 2010 - 6:30 PM |
Enthusiast Joined Jul 12, '08 Currently Offline Reputation: 5 (100%) |
the 5sfe usually comes with the s54 transmission. I dont think you'll be able to just change the gear ratios, cars aren't as simple as lego's unfortunately and theres alot to keep track of when mixing and matching parts. I would just swap in a better condition s54 instead.
if you want longer gear ratios then go with the e153 from an mr2/v6 camry/solara. with an mr2 e153 you will need to convert it to FWD, and you will need hybrid axles regardless of which e153 you find This post has been edited by enderswift: Aug 18, 2010 - 6:39 PM -------------------- |
Aug 18, 2010 - 7:06 PM |
the 5sfe usually comes with the s54 transmission. I dont think you'll be able to just change the gear ratios, cars aren't as simple as lego's unfortunately and theres alot to keep track of when mixing and matching parts. I would just swap in a better condition s54 instead. if you want longer gear ratios then go with the e153 from an mr2/v6 camry/solara. with an mr2 e153 you will need to convert it to FWD, and you will need hybrid axles regardless of which e153 you find i called a shop and they have an mr2 tranny for a 3s motor ....i guess it is the E153... i heard about this but which hybrid axles will work ? does anyone know ? i saw some threads about it but i lost it EDITED : ok so i did my research there are alot of opinions on this e153 tranny everything is still unclear -can i keep my 5sfe clutch and pressure plate ? -can i use my 98 GT cables ? -can i use my 98 GT mounts ? -can i use the inner mr2 cv shafts and my 98 GT outer cv ? i need an exact parts list to do the perfect swap the first time This post has been edited by chinamandrift: Aug 18, 2010 - 7:58 PM |
Aug 18, 2010 - 7:57 PM |
Enthusiast Joined Nov 10, '09 From Louisiana Currently Offline Reputation: 5 (100%) |
MR2 inner axles. Celica All-Trac Outers.
Aug 19, 2010 - 11:01 PM |
st205 front rear/mounts
st205 shift cables -------------------- QUOTE "And, as always, your friendship, help, and dedication to the advancement of Texas Celica dominance is GREATLY appreciated. Thanks bro." -DEATH 1994 GT: V6 swap, 5speed E53 W/ LSD, All Power, now RED 1995 ST: SOLD @273k miles, Auto, all power, CarPC, White 1994 ST: Totaled, 5spd, all power, Red RIP 07/09/09 @ 241,810 1994 Lexus LS400: This is my new DD |
Lo-Fi Version | Time is now: November 23rd, 2024 - 8:59 AM |
