> GT4 front caliper alternatives?
post Aug 19, 2010 - 3:03 AM
luka
Joined Jul 23, '08
From Hawaii
are there any alternatives to the factory GT4 calipers that aren't $1,300+?
Its one of the few hardware pieces i'm missing for my project.
I doubt my stock GT calipers are strong enough to handle & judging by the size difference in hubs, even big enough to consider using.
post Aug 19, 2010 - 3:27 AM
Johnnyny
Joined Apr 28, '09
From York pa
ive seen a 4th gen all trac with tacoma 4 pot brakes nit the same gen but im sure dat it could be done celicatech somewhere, you have the lexus ls400 four pot also there are more on here somewhere look around
This post has been edited by Johnnyny: Aug 19, 2010 - 3:59 AM
post Aug 19, 2010 - 4:13 AM
vincent_doggy
Joined May 25, '06
From Hong Kong
QUOTE (luka @ Aug 19, 2010 - 4:03 PM) *
Why cost $1300+? Order brand new from Toyota or what?
PM me if you want, I got a set laying around, could trim down the 315mm rotor to 300mm
post Aug 19, 2010 - 9:34 AM
luka
Joined Jul 23, '08
From Hawaii
thanks for the replies, I'll check on the tacoma & ls400. pm sent.
post Sep 2, 2010 - 8:47 PM
BonzaiCelica
Joined Apr 24, '08
From Orange County, CA
does anyone know where we can find a set of double piston front calipers found on ST202 Celica with superstrut suspension???!!!
post Sep 6, 2010 - 7:56 AM
nsxtypeR
Joined Jan 3, '06
From The Netherlands
No longer in need for them since I switched to st205 calipers
JDM ST205
post Sep 6, 2010 - 3:00 PM
BonzaiCelica
Joined Apr 24, '08
oh really, is there a rebuild kit for them how many miles on them, cost?? your car came stock with superstrut suspension???
i mean these type of brake calipers.
This post has been edited by BonzaiCelica: Feb 26, 2013 - 4:42 PM
post Sep 7, 2010 - 7:16 AM
nsxtypeR
Joined Jan 3, '06
QUOTE (BonzaiCelica @ Sep 6, 2010 - 3:00 PM) *
The've done 190000km. There is a rebuilt kit available: toyota part number 04479-20210
In the Netherlands, the rebuilt kit is approx €50,- ($64)
They were factory fitted on my car, but due to an 3S-GTE engine swap, I replaced them for ST205 calipers.
If you're interested, feel free to make me an offer.
Shipping costs are a killer though.....€ 104,10, which is about $134,02 at todays exchange rate
JDM ST205
post Sep 7, 2010 - 9:47 PM
BonzaiCelica
Joined Apr 24, '08
OK thanks for that information, I'll keep that in mind when I'm doing my front brake conversion.
post Sep 28, 2010 - 3:07 PM
BonzaiCelica
Joined Apr 24, '08
so your saying you have done 190,000 km on the brake calipers. which is equivalent to 119,000 miles!?
How about the brake pads, are they the same size as the ST204/ST202 Single piston caliper that came on McPherson strut suspension??
This post has been edited by BonzaiCelica: Sep 28, 2010 - 3:16 PM
post Sep 28, 2010 - 4:16 PM
DEATH
Joined Dec 19, '07
From tx
QUOTE (luka @ Aug 19, 2010 - 3:03 AM) *
You'd be surprised how good the GT brakes work on even a decently high HP swapped car. I have great braking response and I'm running 18-20PSI on a 3S-GTE
It's been proven the stock GT brakes are as good as ST-185 dual pots
IMO ST-205 or leave it stock [Unless of course you want to pay waaaay too much for the Brembo namebrand instead of Celica stamped Brembo brakes LOL wink.gif ]
QUOTE (luka @ Aug 19, 2010 - 9:34 AM) *
thanks for the replies, I'll check on the ls400. pm sent.
This post has been edited by DEATH: Sep 28, 2010 - 4:18 PM
SUSP: Tein/Bilstein/SusTech/
EXT: WRC/TRD/404
Slow down Paul Walker.
post Sep 28, 2010 - 7:34 PM
Culpable04
Joined Apr 17, '06
From New Jersey
and for others here is a list of calipers that can be made to work as well
4runner ( there are 2 versions of them accomodating different sizes of disc )
Supra TT
IS300 trd brakes
any big brake kit designed to work with Scion tC and 7th gen Celica GTS
post Sep 28, 2010 - 9:27 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
ls430 calipers
On alltrac.net they got the new tundra calipers to bolt right up.
94 Celica gt white (sold)
post Sep 28, 2010 - 9:41 PM
Culpable04
Joined Apr 17, '06
From New Jersey
QUOTE (bccentaur3 @ Sep 28, 2010 - 10:27 PM) *
ls430 calipers
I forgot about tundra, there are 2 different calipers as well, both can work.
the LS430, depending on the year they need different work in order to fit. but also doable
actually, instead of asking about calipers, people should research brake disc, that's the hard part, is easy to bolt the caliper to your knuckle, but finding a disc that will suit the caliper / knuckle is the tough part.
so far I know Cadillac Catera disc with 5 x 100 drilled on them can work with ST205 disc.
are there any others that you guys know of ?
post Sep 29, 2010 - 1:20 AM
luka
Joined Jul 23, '08
From Hawaii
QUOTE (Culpable04 @ Sep 28, 2010 - 8:34 PM) *
Supra TT
IS300 trd brakes
yeah, just waiting for them to get here hehe.
Found a bunch of places in the UK for rotors, but shipping them into the US might make it hard. Found a couple of other leads in Japan, potentially cheaper since it's much closer.
post Sep 29, 2010 - 10:07 AM
nsxtypeR
Joined Jan 3, '06
QUOTE (BonzaiCelica @ Sep 28, 2010 - 4:07 PM) *
Correct.
No, the're a little bit bigger than single piston calipers from the McPherson strut
JDM ST205
post Sep 29, 2010 - 6:33 PM
BonzaiCelica
Joined Apr 24, '08
what are the aftermarket brake pad options as far as the dual piston superstrut brake calipers???
I see that TRD has them for $155 for the front pair and $155 for the Rear pair plus shipping, its not really good to mix and match brake pads right, by this I mean having trd brake pads in front and hawk hps street pads in the rear!
This post has been edited by BonzaiCelica: Sep 29, 2010 - 6:35 PM
post Sep 29, 2010 - 8:59 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
Well the ls430s I have are monobloc 4 piston calipers in the front and 2 piston in the rear. You will need a brake adapter that can easily be made using aluminum blocks. The thing you guys fail to consider is the brake bias. Now if you guys are all about having massive calipers then more power to you, the point of upgrading your brakes is to gain stopping performance.
We need a the ST and GTs stock caliper piston diameter then we can go from there on brake bias.
post Sep 30, 2010 - 10:29 AM
UniqueGT4
Joined Sep 30, '10
From Bklyn
So can I use GT4 brakes cailper on my 95 GT and if so how or what do I have to do to fit them
(Oo__oO) 1995 Celica GT 2.2L. 5sfe coupe She stock for now
post Sep 30, 2010 - 12:11 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
Culp did a write-up on how to. It looks fairly easy, once you find the right rotors to use.
Lo-Fi Version Time is now: December 12th, 2024 - 9:07 AM
