> Huge misfire, Help please. Misfire issues
post Aug 19, 2010 - 8:53 AM
krmendez8
Joined Aug 19, '10
From orlando
ive got a 94 gt
I got a misfire when I idle at 2k to 3k rpms. Ive changed spark plugs, wires, cap and rotor and distributer coil. Im stuck on this. Im wasting so much gas.. getting like 20mpg. any ideas?
thanks in advance
post Aug 19, 2010 - 1:21 PM
Nartanian
Joined Mar 26, '09
From Minnesota
What cylinders misfire? I say do a compression test. You might be misfiring due to low compression.
"God created turbo lag to give V8's a chance"
post Aug 19, 2010 - 2:07 PM
mgnt232
Joined Mar 16, '09
are you burning up any oil (i assume coolant could do it as well) When I had my old 7a I replaced all this stuff, but i did a test (cylinder leakage test? idr now) and found that the piston ring in cylinder one was bad, and so much oil (i burned a quart a day minimum) was getting in the combustion that it wasnt actually firing, and causing it to misfire. Just an idea to rule out smile.gif
- 6GC for Life -
>Semper Fi<
1994 Cupra :p 3sgte
1995 Celica ST DD
1969 Chevelle SS
alllll balls. P2 approved!
post Aug 19, 2010 - 10:43 PM
chinamandrift
Joined Apr 7, '09
From cali
need more info ...first off Idle at 2k to 3k .....techinically thats not idling ...unless its at 2-3k without you touching the pedal
most people interpret a missfire as many different things
can you explain more in depth how you can recreate this missfire ?
your speed mph ? are you on the throttle 100% ? has the car have recent work ? when did this start happening ? during this missfire what kinda noise do you hear ?does the rpm stumble? was this car non operative for a long time? any smoke during missfire? any smoke at start? strange smells ? does it happen as your moving the throttle ? is your engine covered in oil dirt or grime heavily anwhere?
Lo-Fi Version Time is now: November 30th, 2024 - 4:05 AM
