help: strange rear suspension part |
Aug 20, 2010 - 2:19 AM |
Enthusiast Joined May 3, '09 From jacksonville/flemming island florida Currently Offline Reputation: 1 (100%) |
ok so on the rear suspension of my 94 stx coupe there was a thick rubber doughnut-like gasket/spacer that sat between the top part of the spring and the bottom of the strut mount. When i looked at the illustation from a toyota catolog it wasnt there so i removed them, afterwarsd my car makes a light clunking sound on certain bumps. Atm i can only find one of these spacer/gasket type things does anyone know where i can find another?
-------------------- 94 stx coupe, super mario kart beater
87 toyota 2wd truck, rebuilding engine 85 celica gt-s project |
Aug 20, 2010 - 7:39 AM |
ok so on the rear suspension of my 94 stx coupe there was a thick rubber doughnut-like gasket/spacer that sat between the top part of the spring and the bottom of the strut mount. When i looked at the illustation from a toyota catolog it wasnt there so i removed them, afterwarsd my car makes a light clunking sound on certain bumps. Atm i can only find one of these spacer/gasket type things does anyone know where i can find another? Try getting one at a junk yard for the time being. But in other words, since you took them out, that is the reason there is so much noise. The rubber acts as kind of like an insulator. |
Aug 20, 2010 - 10:23 AM |
You removed the bump stops... Bad move. Check www.twosrus.com. I think Dave sells kyb replacements.
Aug 20, 2010 - 12:24 PM |
You removed the bump stops... Bad move. Check www.twosrus.com. I think Dave sells kyb replacements. no the bumpstops are still there, this was more like a spacer -------------------- 94 stx coupe, super mario kart beater
Aug 20, 2010 - 1:00 PM |
Picture of spacer?
Lo-Fi Version | Time is now: January 9th, 2025 - 1:43 AM |
